WATER PUMP
Old Aug 18, 2002 | 02:59 AM
Voltech_LT4's Avatar
Voltech_LT4
Cruise-In IV Veteran
Default WATER PUMP
I changed out my water pump today. I was excited I had finished....
I added the coolant and started her up.....the temp just kept rising and rising and rising.... I tried buying a new thermostat, bleeding the air by the thermostat housing, flushing the coolant out of the radiator, and it still is doing the same.
Question? Bad water pump?
my car never overheated before the pump puked. Is there any way to tell if the pump is actually working or not? I hate to take that thing back off and get another but I think im running out of options....any ideas?
any help would be greatly appreciated.
vr,
volt :cheers:
Old Aug 18, 2002 | 09:24 AM
STL94LT1's Avatar
STL94LT1
Default Re: WATER PUMP (Voltech_LT4)
Please don't take this as an insult, but did you attach the coupling from the old waterpump to the new one. Also, it sounds like your new thermostat may not be opening.
Old Aug 18, 2002 | 09:33 AM
ittlfly's Avatar
ittlfly
Default Re: WATER PUMP (STL94LT1)
yep
Old Aug 18, 2002 | 09:40 AM
Nathan Plemons's Avatar
Nathan Plemons
You can check to see if it is pumping. When it's cold open up the coolant reservoir. Fire it up and you should see a small trickle coming in from the side. Rev it a little and it should become a decent stream. If not than it's not pumping. BTW, this will work regardless of if the thermo is open or not.
I don't think your pump could be "frozen" or you'd be hearing some pretty bad noises. The pump is driven off the timing chain, so it would have a hard timing freezing without breaking something else.
I would go back and double check that your drive thingy is in place. I know it sounds stupid, but you can't take anything for granted. I couldn't line up two freaking dots apparently when I installed my gear drive. I don't know why my car ran so bad :smash: :smash:
Old Aug 18, 2002 | 01:16 PM
1996man's Avatar
1996man
Default Re: WATER PUMP (Nathan Plemons)
hey nathan plemons, exactly how fast of a 12 are you running with 330 rwhp thats pretty impressive? what kind of tires?
Old Aug 18, 2002 | 01:45 PM
Voltech_LT4
Default Re: WATER PUMP (ittlfly)
coupling? Do you mean the thermostat housing ?
Old Aug 18, 2002 | 01:53 PM
STL94LT1's Avatar
STL94LT1
There is a coupling that attatches the back of the waterpump to the engine. It has to be removed from the old waterpump and installed on the new one before reassembly.This coupling drives the waterpump.
[Modified by STL94LT1, 5:56 PM 8/18/2002]
Old Aug 18, 2002 | 01:57 PM
Voltech_LT4
hmmm, does anyone have a pic? I dont remember anything on the back of the pump that comes off. The only thing I took off the old pump was the coolant temp sensor and the thermostat housing. That is most likely my problem if its not obvious. Im happy if thats the problem....Ill look at the old one again today. ANy pics would be great.
vr,
volt
Old Aug 18, 2002 | 02:34 PM
Nathan Plemons
Default Re: WATER PUMP (1996man)
12.87 @ 112.79 is my personal best on my street tires. That's also on one of my typical lousy 60' times. The best I've ever done in the 60 department is 1.91. I'm pretty sure there was more in it, but I never found it. After the heads I hope to be able to run somewhere in the 12's without really trying that hard.
BTW my street tires are Kumho Ecsta 712's
To WATER PUMP
