84-87 spindles same as 88-96?
there is a kit I'm looking at and for the 84-87 cars its all 4 corners
when you get to the 88-96 there are only kits for the front because of how the e-brake is integrated into the caliper rather than a drum style, which makes the mounting locations on the rear spindle different
does anybody know if the older spindle will mount up to the newer cars?
You would be much better advised I believe to either consider a package that uses a smaller caliper for the E-brake function or perhaps the "StreetShop" package and add packages based on the use of that package. There's no inexpensive way to accomplish what you'd like to do.
Do you have 18" or larger wheels?
Do you actually have a need for the larger X 4 or just looking for the "BLING"?
yea we actually need to go to a nicer, more surface area brake
we get a good amount of fade pretty soon in as well as we have actually boiled them before (with a high temp fluid) and thats not a good feeling when you're brake light comes on and the pedal goes to the floor
we are also getting a new front black skirt under the bumper and running vents through it
I'd think that anything advertised for the early X 4 is likely older product anyway and would be much more difficult to service parts for. I wouldn't even consider most of those even tough they're from FAMOUS NAME vendors.
