91 Headlight Control Module
Old Jun 22, 2015 | 09:36 AM
aklim's Avatar
aklim
Default 91 Headlight Control Module
I had sudden failure on both sides to pop up. Per FSM diagnosis, it is the module. Since it is NLA, like many parts for our cars, who is the best vendor for it or does it matter? I see they are reproduction parts and the prices go from $140 to $200. Not sure. Any advice? TIA
Old Jun 22, 2015 | 09:42 AM
antfarmer2's Avatar
antfarmer2
Did you try to clean the connections.
Old Jun 22, 2015 | 09:51 AM
aklim's Avatar
aklim
Twice. No go still. They even have dielectric grease as a last ditch attempt.
Old Jun 22, 2015 | 09:58 AM
antfarmer2's Avatar
antfarmer2
And the fuse is good and clean......never replaced one but would see if you could get one local in case you have trouble.
Old Jun 22, 2015 | 09:59 AM
aklim's Avatar
aklim
It gets power just that it won't send out power.
Old Jun 22, 2015 | 10:41 AM
antfarmer2's Avatar
antfarmer2
Sounds like you found it.
Old Jun 22, 2015 | 11:34 AM
aklim's Avatar
aklim
Yes i did. Now to find a module at a decent price and not a used one or reproduction if possible
Old Jun 22, 2015 | 12:59 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Not sure if they are interchangeable but the C5 uses one that looks identical. Maybe there is a way to CrossRef them?
http://www.ebay.com/itm/like/131525239819?lpid=82&chn=ps
http://www.ebay.com/bhp/corvette-headlight-module
Old Jun 26, 2015 | 05:56 PM
aklim's Avatar
aklim
1997 2004 Corvette C5 Headlight Control Module Flip Up Headlights | eBay
It probably is. I decided to buy a NOS item http://www.ebay.com/itm/141698561428?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
A couple things I noticed. I fawked up. It was for a Buick Reatta, Pontiac Fiero, Firebird and Sunbird. I noticed it after it was on the way. However, a contract is a contract is a contract so I had to hope it works or dispose it myself. Bought it for $180 plus $9.99 shipping. Got it today.
Hooked it up and it worked. I got the headlights working despite my stupidity.
2 things I noticed. 1 is that there are no felt pads to cushion it from the wheelwell. I took the old ones and put glue and it works. Next is there are some brass inserts that the attachment screws go into. Fortunately, the old ones were recoverable and I made that work.
Now I have lights. HAPPY again.
Old Jun 26, 2015 | 06:19 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Great info.
Old Jun 26, 2015 | 06:41 PM
aklim's Avatar
aklim
Anyone know how good the reproduction units are?
Old Jun 27, 2015 | 12:48 PM
aklim's Avatar
aklim
OK. Now we have an issue. I smelled something burned and pulled apart the old module. Stink of burnt circuits was VERY strong. Looked at it and 3 points around the board were burned. Also there was some water.
Looks to me like water contamination and since most of us know water and electricity don't get along, maybe we need to take out the module and seal the edges shut so no water gets in?
Old Jun 27, 2015 | 05:52 PM
kimmer's Avatar
kimmer
What a bummer.
Old Jun 28, 2015 | 09:49 AM
kg4fku's Avatar
kg4fku
can you post pictures of what you found?
Old Jun 28, 2015 | 10:15 AM
aklim's Avatar
aklim
Water droplets present when opened
Old Jun 28, 2015 | 10:32 AM
kg4fku's Avatar
kg4fku
I would have to agree to the water intrusion theory as the culprit.
Looks like both transistors need replacing (BUZ10), two zener diodes (Z1, Z2) Z3 appears ok, C1 appears compromised and Q5 appears to be split.
So far about 15 dollars worth of parts it the board doesn't need repairs. If you can find the parts.
Could you flip it over and post a picture?
Old Jun 28, 2015 | 10:46 AM
kg4fku's Avatar
kg4fku
It would also be interesting to note the replacement part circuit board number.
Would you be willing to take the new one you have apart and post a picture of the board?
The part number of the board (16509737-4), which is written on the bottom of the board itself, crosses to the 3rd gen firebirds. Is this the first time this part has been replaced?
To 91 Headlight Control Module
Old Jun 28, 2015 | 11:25 AM
kg4fku's Avatar
kg4fku
Little more digging revealed there are multiple control boards that do a similar function but not necessarily work in different applications.
http://www.fiero.nl/cgi-bin/fiero/sh...tyle=printable
Seems that some of these boards are wired internally to be different for specific applications.
Curious if anyone might have the board number from a C5 Corvette control module?
Old Jun 28, 2015 | 03:00 PM
Mishawaka's Avatar
Mishawaka
What does the other side of the board look like? The transistors are available(just looked them up) not sure about the the diodes since I cant see the number. I'd scrub the board with lacquer thinner and old toothbrush then use a DMM to check the components. I used to repair electronics and this should be an easy fix. Can always use it as a backup or sell as repaired.
Old Jun 28, 2015 | 08:01 PM
aklim's Avatar
aklim
