84 leaky brake booster
Old 06-24-2015, 09:06 PM
ToniJ1960
ToniJ1960's Avatar
Default 84 leaky brake booster
My brake booster is leaky I hear it hiss when I push in the pedal, and the pedal is hard to push. A couple times the engine seemed to speed up when I pushed the brake pedal down and the car didn't want to stop at all.
Im not sure if that's from the booster or my foot maybe hitting the accelerator when it happens I cant take time to look at the pedal. The reason I think it could be my foot hitting the gas when its on the brakes is the PO put a large metal foot plate over the brake pedal.
Anyway I have two questions. Is it likely that the booster can do this itself?
If I pull the hose off the booster and block it will I be able to drive to go get a brake booster.
Old 06-24-2015, 11:39 PM
Cliff Harris
Cliff Harris's Avatar
You can drive the car the way it is now. Taking the hose off won't change anything except make the engine run better. It would be best to remove the hose from the booster and plug the vacuum hose because it is a vacuum leak.
It will just take more muscle than usual to make the car stop. You need to remember that there will be more pedal pressure required than normal to be ready to start braking early.
Old 06-25-2015, 12:41 PM
ToniJ1960
ToniJ1960's Avatar
Is it possible it could damage the mc this way or cause any invasion of air into the system something to bend etc from pushing so hard on the brake pedal?
Do you think that's whats causing the rpm runaway on the rare occasion? Im trying to make a better habit of getting my foot wayyyyyy over since that pedal bracket is so big and so close to the gas pedal.
Old 06-25-2015, 10:17 PM
jv9999
jv9999's Avatar
Why not remove the non-factory pedal piece? It sounds dangerous. You won't hurt the M/C without boost. Hopefully you have the metal booster as the plastic ones are fairly fragile.
Old 06-26-2015, 07:25 AM
Pres712
Pres712's Avatar
I just replaced mine that had the same problem. It's a fairly simple job. I bought a booster from Auto Zone and followed a video on You Tube. Three hours and $120 later, it's fixed.
Old 06-28-2015, 12:04 PM
GQ-ROD
GQ-ROD's Avatar
Just replace it, i've had to replace 2 rebuilt ones in 3 years, not hard to do just patience.
Not expensive, all you have to do is carefully move the mc aside with lines intact to remove the booster.
To 84 leaky brake booster
Quick Reply: 84 leaky brake booster
