I could swear I saw 4 oz. additive somewhere, in either the 85 or 90 FSM. at this point, I wouldn't bet on it though. I recently serviced the differential in my 85. drained as much as I could get out, and pretty sure I got most of it using my transfer pump. I added 4 oz of additive, and approximately, 1.75 (1 qt.) bottles of gear oil. I used Castrol, limited slip, 80W90, filled to the plug. curiosities up - going to follow this thread. in the mean time, I'm going to check out my FSM's.
FWIW, I've only used one, 4 oz. bottle all the way back to my C3 days.
edit: I might add that the Castrol gear oil bottle, is stated as "limited slip," so I'm assuming it has some sort of additive. nowhere on the bottle does it say, do not add additive or additional additive not required. FWIW....
yes I know I should've used the search function, but I did and it said 3.75 qts.
What I want to know about is the additive. I bought redline gear oil(75/90) and a bottle of additive.
1) do I need the additive with the redline lube?
2) how many bottles of additive(4 oz), I saw 2 bottles somewhere?
TIA
You need to determine if you'd like to use the additive OR NOT. What does the Red Line container say? Likely says NOT REQUIRED but many/most do and I'd think 1 sufficient. If you had no issues in tight turns with chatter I see no reason for MORE.
Where did you come up with the 3.75 QTS? Put the additive in FIRST and I believe you'll be hard pressed to do 1 1/2 QTS of the Red Line.
Post back with the amount you actually were able to get in until the fill plug seeped.
Is there a particular reason you chose the Red Line product?
Its a newly rebuilt unit and hasn't been on the car.
Redline, royal purple, mobile1....some of the best
This is where I found the 3.75 capacity and TWO bottles of additive (our very own Vader), but the empty rear looks like it will hold more than 1.5 qts.
Is the clutch pack fresh/new also or just bearings/seals. If the clutch pack were new there might be reason to maybe consider 2 additive especially if there's nothing noted on the Red Line container.
Perhaps the fill value is an error in pints vs. quarts but I'd think you'll find it will be substantially less than 2 Qts. Yours being a fresh build and a "dry" install is maybe more reason to have you post back with what you actually find for the fill value.
I don't believe you mentioned D44 or D36 so you might mention that also. For a "suction" to service I don't believe there would be a substantial difference in the fluid required BUT being a "fresh/dry" build it might interesting if you noted which.
so do you think I can add the 2 additives and call it a day or will they cause damage or whatever?
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Off the car? How is it sitting/ Pinion up? or as it would be leveled in the car?
Geez. Just fill it up!
In the car installation complete - if you assemble it out of the car you might want to do one quart plus the additive maybe and circulate it manually. Final fill is "in the car".
per the 1985 FSM, section 0B-6, maintenance and lubrication, under limited-slip differential rear axle, IT STATES "...before filling, add 4 ounces of GM part number 1052358 or equivalent." as far as the 3.75 thing, WV may be right on the typo thing (pts vs. qts). w/ the above - just fill it up (to the plug level)!
there's probably a reason they sell this stuff in 4-oz bottles -
Description: Overhung pinion gear
Limited slip differential type: Standard, disc clutches
Drive pinion offset: 1.50" (8.5" ring gear), 1.125" (7.87" ring gear)
Drive pinion type: Hypoid
Number of differential pinions: Two
Pinion/Differential bearing adjustment: Shim
Driving wheel bearing: Tapered roller Lubricant capacity: 3.75 pt
Lubricant type recommended: GL-5 gear lubricant
Lubricant SAE viscosity: 75W-90
it states pints NOT quarts. that capacity would make sense if it's total capacity - oil plus additive. I would still follow the FSM on the quantity of additive though.
