Half shaft u-joint
Old Jun 29, 2015 | 01:09 AM
vetteguy22's Avatar
vetteguy22
Default Half shaft u-joint
Hope someone can help.
I need to replace the driver side u-joint on the half sift of a 1993 ZR-1.
Does anyone have the brand and part number for a good quality solid
u-joint?
Thanks,
Rob
Old Jun 29, 2015 | 05:33 AM
cohocarl's Avatar
cohocarl
u-joint?
Thanks,
Rob
Spicer 5-1350X
Forum search results: 5-1350X
I just replaced all 4 of mine with these, and I also had purchased a http://www.ebay.com/itm/4-in-1-Ball-Joint-Service-Auto-Tool-Set-2WD-4WD-Auto-Repair-Remover-Installer-/290834266599?hash=item43b712b9e7&item=290834266599&vxp=mtrlast year (should be able to rent them at parts stores) that I clamped the tool in my vise which made pressing and removing the joints/caps a breeze.
Old Jun 29, 2015 | 06:33 AM
kg4fku's Avatar
kg4fku
The Spicer catalog calls for 5-3613x for the driveshaft and 5-3615x for the axle shafts.
Old Jun 29, 2015 | 06:40 AM
hcbph's Avatar
hcbph
I just did mine last year, used Moog solid ones from Rock Auto.
Here's a good article that shows a lot of detail, just go through the part that covers pulling the half shafts: http://www.digitalcorvettes.com/foru...d.php?t=144562
A couple of tips here, one is put a piece of carpet under where you're working to stop any screws you drop (and you will drop something) from running away.
I also made an adapter tool that let me press the u-joints out using a hydraulic press and worked well for me: http://s162.photobucket.com/user/hcb...tml?sort=3&o=4
It's not terribly hard but you can do it if you're patient and methodical in your approach.
Old Jun 29, 2015 | 08:14 AM
antfarmer2's Avatar
antfarmer2
u-joint?
Thanks,
Rob
Don't do it halfass do both sides. all four
Old Jun 29, 2015 | 08:37 AM
cohocarl's Avatar
cohocarl
Yes, those are the joints with zinc coating on the caps to reduce galvonization with the aluminum halfshafts, and would be a better choice in the long run.
I've read where some use the 1350X's along with some anit-seize.
Would also be a good time to replace wheel bearings if needed. MUCH easier with 1/2 shaft removed.
Old Jun 29, 2015 | 04:09 PM
Mishawaka's Avatar
Mishawaka
I thought Spicer discontinued the non galvanic? I just replaced my drivers side yesterday with Precisions anti galvanic. Wish I knew I could have gotten Spicers.
Old Jun 29, 2015 | 04:41 PM
WVZR-1's Avatar
WVZR-1
Spicer only reinstated the "coated" product a couple years ago or so. The 1310's can be purchased quite reasonably BUT the 1350's are VERY expensive - VERY
I'll wager you wouldn't have paid the price.
Old Jun 29, 2015 | 07:28 PM
Mishawaka's Avatar
Mishawaka
Yeah if they were more than $30 each I would have passed. I really just wanted to at least get the non galvanic ones.
Old Jun 29, 2015 | 07:39 PM
scotth48's Avatar
scotth48
replaced mine last year on my '93. I bought from two different places. They were all Spicers, but had to wait from the one place a truck parts company (FleetPride) that was a Spicer dealer and the other place was a drive shaft company, I think they are listed here on the forum. I don't know where the bills are, but they were expensive. What I have listed are the following:
5-3613X for main drive shaft. 2 required.
5-3615X for 1/2 shafts. 4 required.
2-70-18X bearing strap kit for drive shaft bearing 5-3613X. 2 required.
3-70-48X bearing strap kit for 1/2 shaft bearing 5-3615X. 4required.
It must be noted that the strap kits bolts are different threads, one is metric and the other is S.A.E. but can't remember which one.
Old Jun 29, 2015 | 08:01 PM
scotth48's Avatar
scotth48
It was "Denny's Drive Shaft, Kenmore, New York. Almost $ 400.00
Old Jun 29, 2015 | 10:33 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Replace all of them at once.
Or do the job twice.
Old Jun 29, 2015 | 10:43 PM
Mishawaka's Avatar
Mishawaka
I just the drivers side and planned on the passengers side after the holiday. I don't think it will be a big deal. Besides, I read quite a few threads about this and seems like its always the drivers side that needs replaced. I replaced my bearing hub along with the ujoints since I had it all apart.
Old Jun 30, 2015 | 06:58 AM
WW7's Avatar
WW7
both sides turn the same amount, why would only one side wear out........Do both sides or you will be sorry later on....WW
Old Jun 30, 2015 | 09:15 PM
JrRifleCoach
Well, then your good to go.
Old Jul 1, 2015 | 04:47 PM
cohocarl's Avatar
cohocarl
Coriolis effect. In Australia, the passenger side wears out first.
Old Jul 1, 2015 | 05:15 PM
scotth48's Avatar
scotth48
Your passenger side would be the drivers side since you drive on the wrong side of the road!!!
To Half shaft u-joint
Old Jul 2, 2015 | 08:09 AM
WW7's Avatar
WW7
yeah, lets confuse everyone more then we usually do............WW
Old Jul 3, 2015 | 12:17 AM
JrRifleCoach
Cool, I'll start.
Which side is the passenger side?
Old Jul 4, 2015 | 06:04 AM
kg4fku's Avatar
kg4fku
Cool, I'll start.
Opposite side of the driver.
Usually distinguishable by the loud screams emanating from it.
