'89 Check Eng on but no codes
Anyone ever seen that? We are going to exchange the ECM again this afternoon but in the mean time will confirm no short to ground in circuit 419 (brown/white) that runs the light from ECM to DIC.
FSM has NO diagnostics for Light on & no codes that I could find...
TIA.
If you had no problem with the ECM but replaced it anyways, you probably have the new ECM not fully connected or dirty contacts, I'd clean them and make sure you get that nice 'snap' sound when you connect up the ECM cables.
It could be the ECM of course, but more likely something you did or dirt got in there.
I replaced my ECM on my '89 at 100k miles since my ave/instant miles readout wasn't working - after over 20 years, its nice to have that fixed.
14 is gone but then he starts calling me with this no codes but light still on... I walk him through a few things over the phone & he keeps saying no codes...
Late yesterday he shows up at my shop & says, still on, I pull codes, 12x3 & then it starts to throw a new #, he starts to say, see no codes... duh. code 33! (imho it was prob. doing that the whole time?)
So, run the diagnostics from the FSM, all the tests pass just fine... clear code several times over the tests & it comes back about 25 seconds after start. He has already replaced the MAF, both relays & I helped check some of the wiring... I also reset the TPS which was a little low. A few threads on here suggested checking base idle but they had to do with modified setups and/or larger TBs.
He has ordered a new MAF from local parts place but I'm not sure that will stop it. I'm going to suggest he check the wiring back towards the main harness with a fine tooth comb...
Anyone else have any suggestions?
You might have a broken wire.
Wait about ten min.
