02 sensor numbers
Old Aug 18, 2002 | 07:29 PM
Kehrer923's Avatar
Kehrer923
Default 02 sensor numbers
My o2 sensors read from 800-900 on the diacom program anyone know how lean or rich that is? 93 LT-1 383 stroker
Old Aug 18, 2002 | 10:57 PM
95CYC4's Avatar
95CYC4
Default Re: 02 sensor numbers (Kehrer923)
Some guys like to be a little above 900, but 800-900 is very good. You are right where you want to be, so I would keep the settings you have.
Old Aug 19, 2002 | 09:36 AM
honas's Avatar
honas
880 is supposed to be perfect.
Old Aug 19, 2002 | 12:14 PM
Kehrer923's Avatar
Kehrer923
Default Re: 02 sensor numbers (honas)
Well the corvette manual says that it should be like 450 and it seems to me to be running real rich
Old Aug 19, 2002 | 01:10 PM
dgoodhue's Avatar
dgoodhue
Is this WOT or normal closed loop driving?
Old Aug 19, 2002 | 05:39 PM
Kehrer923's Avatar
Kehrer923
Default Re: 02 sensor numbers (dgoodhue)
normal driving
Old Aug 19, 2002 | 09:49 PM
95CYC4's Avatar
95CYC4
The numbers that I refer to are at WOT. I don't know what good idle numbers would be.
Old Aug 20, 2002 | 03:18 AM
Dan Parker '96's Avatar
Dan Parker '96
At WOT the 800-900 range is good..
Here's an example.. please disregard some of the readings (AFR, MAF Hz, Knock, and a couple others as this is an LS1 program used on an LT1).
This is a WOT reading at 119mph. Look at the top graph and the top right numbers for O2 readings
..and here's a look at O2 readings at 70mph cruise... notice that they jump around constantly... That's a sign that they're working well.
[Modified by Dan Parker '96, 1:35 AM 8/20/2002]
Old Aug 20, 2002 | 09:54 AM
dgoodhue's Avatar
dgoodhue
At normal driving in closed loop the O2 sensor voltage is suposed to cycle back and forth between 100 and 900 (looks like a roller coster) If it stuck at 800-900 there is something wrong or the O2 is getting heated enought to get into closed loop.
Old Aug 22, 2002 | 02:30 AM
Kehrer923's Avatar
Kehrer923
I have heated O2 sensors like described on the tech tips
Old Aug 22, 2002 | 04:38 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Are you sure you have heated O2s? 93s came with 2 single wire O2s. If you have converted to heated units, were do you have the power lines run? :crazy:
Old Aug 22, 2002 | 03:34 PM
ConeKLR's Avatar
ConeKLR
At idle a Autoxray scan tool read my drvier side sensor reading was bouncing up and down from around 100 - 800 that's normal. The passenger side sensor was flat lined at .010, that indicated it was not functioning Low Voltage circuit condition.
Old Aug 23, 2002 | 12:06 AM
Kehrer923's Avatar
Kehrer923
Default Re: 02 sensor numbers (ConeKLR)
i have heated 3 wire units that are wired to the wiper motor
To 02 sensor numbers
