Starting issues when hot
Old Jul 2, 2015 | 09:05 AM
yellowvette1992's Avatar
yellowvette1992
Default Starting issues when hot
92 6 spd w/100k. Had fuel pump replaced and was told by mechanic that I need a new ccm because my asr service light, security light and sys light all come on after a few minutes of running. Now another problem. Drove car to work went out after work and it would not start, Car was sitting in 95 degree sun all day. Friend stopped by who has c6 and used to have c4. We talked, he opened hood took out the PCM put it in the refrigerator for about 5 min. put it back in car and bingo it started first time. He said these units are prone to high failure rate when hot. What is the best avenue for me to take to remedy this situation and who is a good vendor to deal with, I really do not want to go to a dealer. Thank you in advance. SANE THE WAVE
Old Jul 4, 2015 | 03:35 PM
yellowvette1992
Checking the internet does any one here on the forum have experience with SIA electronics or can anyone recommend some other vendor to rebuild my PCM. Looks like this is what I need to do to be able to get the car to start consistently. Any advise and help greatly appreciated. Thank you.
Old Jul 4, 2015 | 04:44 PM
knikula's Avatar
knikula
Do you happen to know what a "Rebuilt" PCM consists of? On my son's '92 Eclipse, the electrolytic capacitors reached their design life, and fail, with a visible "bulge". Replacing the capacitors fixes the problem.
Which would be super cheap, if that was the problem. Sometimes the PCM manufacturer pours that nasty silicone over the board, which makes repairing them less fun.
However, I've never seen a corvette PCM up close enough to know...
just a thought.
Old Jul 6, 2015 | 08:57 AM
yellowvette1992
I don't know I have not opened up the PCM to look inside. I am not sure what they do when they repair them. May have to open up the PCM and take a look. Thanks
Old Jul 8, 2015 | 08:49 AM
yellowvette1992
Any one have any experience with SIA electronics or any other recommendation for a PCM rebuild. Thanks
To Starting issues when hot
