VATS.........A detailed explanation for C-4 Tech
Old Jul 7, 2015 | 07:05 PM
MARKRUBYRED's Avatar
MARKRUBYRED
Default VATS.........A detailed explanation for C-4 Tech
I know that VATS (Vehicle Anti-Theft system) has been an ongoing issue with the Corvette community, especially the C-4 group, myself included. When the system stops functioning the way GM designers and engineers planned it can be the most aggravating and misunderstood problem we will encounter. With that said, I wanted to post a link from Lockmasters Inc. that describes the system, how it works and when not functioning, what problems to look for. I wish the author, Steve Young had written the FSM since you do not have to be an MIT Graduate to comprehend.
https://www.lockmasters.com/ecommerc...%20Article.pdf
Enjoy and post your comments, good, bad or indifferent. Further, if this is a dupe, please let me know.
Regards,
Mark
Old Jul 7, 2015 | 07:12 PM
antfarmer2's Avatar
antfarmer2
I vote for a sticky
Old Jul 7, 2015 | 08:02 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by antfarmer2
I vote for a sticky
Probably 70%+ of the stickies are just taking up space and I certainly don't see the need for this to take up any more of the "real estate".
Old Jul 8, 2015 | 01:31 AM
Cliff Harris's Avatar
Cliff Harris
Some of the info in that article is not correct. In early cars the VATS system does not control the SECURITY light. I think that changed in 1990 (not sure). As far as I know VATS never affected fuel pump operation. If you have a car older than 1990 then the battery voltage does not affect the VATS module's ability to read the key resistance.
I looked at the VATS module a few years ago:
https://www.corvetteforum.com/forums...schematic.html
Old Jul 8, 2015 | 01:40 AM
RobertH's Avatar
RobertH
Cruising
Old Jul 8, 2015 | 11:40 AM
kenpeindl's Avatar
kenpeindl
Great article! Definitely a sticky!
Old Jul 8, 2015 | 04:08 PM
aDigitalPhantom's Avatar
aDigitalPhantom
I want to see the 2003 Camaros, and Firebirds that speaks of.
Old Jul 8, 2015 | 04:25 PM
Mishawaka's Avatar
Mishawaka
I have been thinking of buying a keyless entry system for my 92. No alarm, just want it so I don't have to use the key to unlock the door. Will VATS have a problem with that?
To VATS.........A detailed explanation for C-4 Tech
