Hard Start with MSD 6
Old Aug 19, 2002 | 09:35 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Hard Start with MSD 6
I just installed my MSD Digital 6 and am having starting difficulties. It's just when I intitialy start the car, it almost acts like there is a fuel shortage or something. This was installed along with a Compucar Wet Nitrous system. Other than the starting difficulty the ignition system works great.
Has anyone else noticed this problem after installing this MSD 6?
Thanks,
Eric
Old Aug 19, 2002 | 09:58 AM
ZylaRace's Avatar
ZylaRace
Default Re: Hard Start with MSD 6 (HOWSER)
U sure it is not a problem w/ the nitros system? i.e. Leaking extra fuel in?
Generally, the MSD is all or nothing. How does it respond when you bypass the MSD?
Old Aug 19, 2002 | 11:00 AM
Nathan Plemons's Avatar
Nathan Plemons
Did you enable the starting timing retard? I did and the car would barely run. Any time it fell under 1000 rpm's it would die. Without the timing retard it runs perfectly, no real difference except for the lighting bolt it throws for a spark.
Old Aug 19, 2002 | 11:24 AM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Hard Start with MSD 6 (Nathan Plemons)
I agree with Nathan. I could not get mine to work with the start timing retard engaged. Set it in position 2 I think to not let that function work. Check your book to make sure because I can't remember for sure. I think if you had about 14:1 compression maybe that would be useful to have spark retard on startup.
Old Aug 19, 2002 | 11:56 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
No I didn't think to check this, I will during lunch though. I did by this used from a forum member, he had most settings already set. I only had to change one for my application.
Thanks!
Old Aug 19, 2002 | 02:32 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Re: Hard Start with MSD 6 (Bob86ZZ4)
Are you referring to the function where you pick your cyclinders? This is set at 2. Please explain if otherwise.
Thank you.
Old Aug 19, 2002 | 05:54 PM
Nathan Plemons
Yeah that's what I'm referring to. 2 is the correct setting. 6 is 8-cyl with timing retard, you'd be lucky if it runs at all there.
My guess is that this isn't your trouble.
Old Aug 20, 2002 | 11:11 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Well, I tried it with the stock ignition hooked up...it fires right up. So I know it's something with the MSD 6. I did notice that before I start it, if I leave the key in the position with the accesories on for a second (compared to just cranking it quickly) it will fire much better. The MSD doesn't need time to "juice up" does it???
To Hard Start with MSD 6
