Help
Old Jul 11, 2015 | 10:31 PM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
Default Help
I took my 1991 L98 auto. for a drive today ( about an hour ) stopped for dinner, and when we tried to start it again it would not crank. I had power to the lights, radio ect. After setting for almost two hours it started. It happened a couple times before and I changed the starter interrupt relay, but it looks like that didn't fix it. The security system was not armed any of the times this happened. Any ideas about what's going and how to fix it would be much appreciated.
Bob
Old Jul 11, 2015 | 10:47 PM
antfarmer2's Avatar
antfarmer2
Bob
Does it click or try to turn over?
Have your battery tested under load. if you have vats try your other key
Old Jul 11, 2015 | 11:28 PM
Pa'svette's Avatar
Pa'svette
No click. I have the VAT but didn't have the other key with me today. I tried both keys one other time when it did this and it didn't help.
Bob
Old Jul 12, 2015 | 01:26 AM
Silver96ce's Avatar
Silver96ce
Check all connections between battery and starter.
How many miles? Could be the starter solenoid. Same problem last year on my wife's '04 Dodge and it was the starter solenoid - put on a rebuilt starter - now it's fine.
The copper contacts on the solenoid wear pretty quickly and I am surprised how long they actually last. Last year I did some minor upgrades to my '96 and I had to pull the starter out to pull the oil pan. I did a solenoid rebuild and was surprised at how much wear was on the copper ring on the plunger and the the copper contacts inside the solenoid. And the car only has about 54k on it.
Good luck.
Old Jul 12, 2015 | 08:03 AM
antfarmer2's Avatar
antfarmer2
Bob
When trying the other key you need to leave time for it to reset.
Old Jul 12, 2015 | 08:18 AM
Dt86's Avatar
Dt86
I had a similar issue before and this is what I was told by a friend.
"You have to verify that your starter interrupt relay is getting energized...and that if your neutral safety switch is also good. You will see this in the cranking circuit in the book. IF the starter interrupt relays is closing and supplying power to the starter...then it may be the terminals at the solenoid. Make sure your battery cables are TIGHT"
I never had the issue again and didn't check into it further so I don't know what it was. I think in my case maybe it was dirt in the ignition throwing off the pellet resistance? Anyway hope the info helps.
Old Jul 12, 2015 | 09:47 AM
WVZR-1's Avatar
WVZR-1
Bob
How long ago was the "enable relay" changed? People have added another ground to the SER and grounded it to the left kick panel area with success. You need to confirm first that all of the cables are good, connections are clean and that the starter solenoid contacts are good. It might be just wise if the starter is older OR maybe a reman just redo the solenoid contacts and plunger while checking the cables and connections. Do any changes you might need to AFTER confirming all else is good.
"Dt86" pretty well summarized where you need to go.
I certainly wouldn't blame or think VATS the first course of repair. You might consider maybe carrying "both" keys for a while and if it does go intermittent and you have the second with you it would answer the question quickly.
For diagnostics only you might consider a JY visit, collect a connector from the VATS cylinder of any appropriate GM, add the appropriate resistance to the connector and use that as a diagnostic tool. I've friends who have constructed the connector and just carry it in the car. I know none of them that have had to actually use it though.
Old Jul 12, 2015 | 11:58 AM
Pa'svette's Avatar
Pa'svette
Thanks to all you guys. At the risk of sounding stupid what is a JY? I just noticed that the horn is not working and there is no power going to them. Would that be an indication that the problem may be in the VAT?
Bob
The car has 40k miles on it and the relay was just replaced a couple months ago. Only driven one other time since then.
Old Jul 12, 2015 | 01:35 PM
knikula's Avatar
knikula
I had an '96 S10 that would very occasionally not crank, no click, nothing.
Whenever my wife would drive it, it was notorious for refusing to start.
I estimate 95% of the time that it refused to start, she was driving it.
And she very seldom drove it. Apparently, the S10 despised her.
On the rare occasion that it refused to start for me, I carried a hammer with me to rap on the outside of the starter. One sharp blow would get it going.
Finally , one day, it refused to respond to a couple blows from the persuader, and I had to change the starter. Problem solved.
Old Jul 12, 2015 | 02:57 PM
WVZR-1's Avatar
WVZR-1
JY - Junk Yard and NO I don't believe the non-functioning horn is an indicator of VATS. The C4 horns are notorious for not working. Diagnose them as a completely different issue.
Old Jul 12, 2015 | 06:28 PM
Pa'svette's Avatar
Pa'svette
Spent some time in the garage this afternoon. The VAT seems to be working correctly with both keys. Checked all the fuses (both boxes) and relays. Next step is take to the shop, get it up in the air to check the starter and solenoid.
I love the car but can't trust her anymore after leaving me stranded three times. By the way if you ever in West Virgina and need to call AAA expect to be on hold for 30 min. then wait an hour for them to show up with jumper cables. And if it still wont start it's another two hours before the rollback can get there. Luckily after the first guy left the car had cooled off and started. It's been that way every time.
Thanks for all the advise.
Old Jul 24, 2015 | 06:27 PM
Pa'svette's Avatar
Pa'svette
Got the horn fixed. I followed the link you sent. Same problem same fix. Thanks a bunch.
When I disconnected the battery, to take the air bag out, the battery bolt was rusted to the cable end. Could that be my intermittent no start problem?
Bob
Old Jul 24, 2015 | 08:09 PM
Silver96ce's Avatar
Silver96ce
Bob
Yes it can cause of kinds of havoc on the vette. When I got mine, I pulled the battery bolts out of their respective cable ends and cleaned them and the ring contacts in the cable ends. There was a lot of corrosion in mine - the prior owner put in a new battery but neglected to clean them or tighten the bolts properly. I had a problem with the battery seeming to run down and the "SYS" light was flashing on the dash.
Clean them, put an automatic battery charger on it and give the battery a good charge. While you have the battery disconnected find as many grounds as you can and clean them. They are shown in the Factory service manual. Reconnect the battery and see what happens.
To Help
