A/C Delete
Old Jul 12, 2015 | 07:57 PM
jimmers's Avatar
jimmers
Default A/C Delete
So the bracket that holds the A/C broke today. A piece broke at the bolt that goes to the water pump. The AC in my 90' hasn't worked from day so, so I never use it. I figure instead of getting another bracket maybe I should just remove it. My questions are for those who have removed their AC. Which route have you gone? I've read some get the delete kit and some change the water pump and shorten the belt. Does anyone have any tips or steps on actually removing it? What water pump do you need to get? What happens to the belt tensioner? Any help would be great!
Old Jul 12, 2015 | 10:21 PM
rodj's Avatar
rodj
https://www.corvetteforum.com/forums...post1566807620
https://www.corvetteforum.com/forums...post1569586370
Old Jul 13, 2015 | 03:18 AM
Ronaldo's Avatar
Ronaldo
I removed the whole A/C, shortend the belt, changed the waterpump and made my own tensioner at the alternator. You can see a little bit of it in this video.
I made the tensioner from a very cheap "boat screw". Google translate calls it a "turnbuckle" in english
Old Jul 13, 2015 | 08:44 AM
jimmers's Avatar
jimmers
Thanks for the links. I read through that thread a few times last night. Seeing as how the thread is a few years old, I figured people might chime in with new info.
Old Jul 13, 2015 | 11:06 AM
WW7's Avatar
WW7
First off if your bracket is broken, then you would need a new A/C bracket to use the A/C delete kit on your car because the TPIS delete uses the A/C bracket to connect to.. Figure $75.00-$100.00 for a used bracket and the delete kit is $150.00 from TPIS....I went with the delete kit on my 89 and it works fine with the original belt...I have seen cars that have gone with the new pump and shorter belt and if I was to do it over again I would probably go that route, because it makes the engine bay look cleaner...The one problem I see with eliminating the A/C bracket completely is you get rid of your belt tensioner, so you have to adjust the belt pretty often for the first few weeks because of belt stretch...Most guys say after the first few weeks they still have to adjust the tension on the shorter belt but not as often, just like in the old days.......WW
PS...I almost forgot to tell you, when you remove all the A/C parts from your car, the 2 pronged wire connector that hooks to the little on/off relay on the metel tube has to be cut and the wires hooked together to close the circuit, if you don't do this it will cause a few problems..I can't remember exactly what happened because it's been 5 or 6 years since I did mine, but I believe it set a code and stopped other functions on the climate control from working.....Just cut the connector off, and connect the 2 wires together to close the circuit...
Old Jul 13, 2015 | 12:37 PM
jimmers's Avatar
jimmers
Originally Posted by WW7
First off if your bracket is broken, then you would need a new A/C bracket to use the A/C delete kit on your car because the TPIS delete uses the A/C bracket to connect to.. Figure $75.00-$100.00 for a used bracket and the delete kit is $150.00 from TPIS....I went with the delete kit on my 89 and it works fine with the original belt...I have seen cars that have gone with the new pump and shorter belt and if I was to do it over again I would probably go that route because it makes the engine bay look cleaner...The one problem I see with eliminating the A/C bracket completely is you get rid of your belt tensioner, so you have to adjust the belt pretty often for the first few weeks because of belt stretch...Most guys say after the first few weeks they still have to adjust the tension on the shorter belt but not as often, just like in the old days.......WW
Thanks for this, it's great information. I may go the route of eliminating the AC altogether then.
Old Jul 14, 2015 | 04:42 AM
rodj's Avatar
rodj
Coolant fan runs all the time because system thinks the A/c is on
Old Jul 14, 2015 | 05:24 AM
WW7's Avatar
WW7
Right rodj, that was it, now I remember..Thanks.......WW
Old Jul 14, 2015 | 09:27 AM
c4cruiser's Avatar
c4cruiser
Can't you just put a jumper wire between the two connectors in the harness? That way if the A/C is to be reinstalled, it's a simple reconnection of the compressor without having to find the harness connector and rewiring.
When the hoses are removed, it's a good idea to use some plastic or rubber caps to cover the lines going into the evap housing. Use some caps on the hose ends and the condensor too. That will keep dust and debris from getting in so when (or if) you want to re-install the system, you won't have to deal with cleaning everything.
Old Jul 14, 2015 | 12:22 PM
WW7's Avatar
WW7
Any way you want to connect the 2 wires together would work, as long as you complete the circuit........WW
To A/C Delete
