Hey all I used the TPIS pulley to remove the A/C from my 88 Vette (it had not worked for years) now the radiator fan will not kick off. Any ideas on what to do to fix this?
Brian
Sounds like you unplugged the AC Coolant Fan switch.
If you did, you need to jump the Dark Green wire and the Black wire together at the disconnected connector plug.
Note in the diagram below the AC Coolant Fan switch and the AC high pressure switch can be in the opposite position from the diagram,so look at the color of the wires of the connector.
