85 Idle Problem
Old Jul 15, 2015 | 01:05 AM
Jersey Rock33's Avatar
Jersey Rock33
3rd Gear
Default 85 Idle Problem
My 85 Corvette that has an idle problem. Some time ago when the engine warms up and I'm stopped at a traffic light it would seem that the car would stall out but it never did. The idle was increased. Shortly after increasing the idle, I found a problem with the vacuum hoses leading to the Charcoal Canister so the vacuum hoses were replaced and the canister was cleaned. The car now runs alot smoother now but if I ride it locally for about one (1) hour the 'check engine' light appears. While the car is running, and the 'check engine' light is still on and its out of gear, the rpm is measuring 880. I know the ideal idle setting should be 600 to 700rpm.
Has anyone experienced this before and how did you fix it?
I welcome any and all suggestions.
Thank you.
Old Jul 15, 2015 | 09:17 PM
blackozvet's Avatar
blackozvet
Do you know how to read the check engine light via the ALDL to find out what the fault code is ? That will be number 1 thing to do.
Here is a link to the idle / tps setting procedure,
http://www.thirdgen.org/forums/tech-...ml#post1304610
Old Jul 15, 2015 | 09:24 PM
aklim's Avatar
aklim
Thank you.
How did you increase the idle?
What codes?
How did you determine that? the idle is 880? Scantool or tach?
Old Jul 16, 2015 | 12:10 AM
Cliff Harris's Avatar
Cliff Harris
The ECM sets the idle speed. It's programmed into the MEMCAL. It appears that you messed with the "idle" screw, which is NOT the way to do this.
I recommend a minimum idle adjustment to start with:
https://www.corvetteforum.com/forums...post1570563689
Old Jul 17, 2015 | 01:35 PM
Jersey Rock33
3rd Gear
Thank you for your response. I'm going to read the procedure this weekend and tackle the problem. Been busy with the job.
Old Jul 17, 2015 | 01:38 PM
Jersey Rock33
3rd Gear
Thank you for your response. I downnloaded the information and will read it this weekend. The job has been keeping me busy with deadlines, but with your advice it will be resolved. Thank you.
Old Jul 17, 2015 | 01:57 PM
aklim's Avatar
aklim
Jersy, get a scanner and be done with it. You will need it in future so why not get it now, adjust with scanner and learn how to do it from ECM output?
To 85 Idle Problem
