88' won't start... suspect fuel pump...
Old Jul 18, 2015 | 08:53 PM
joendoodle's Avatar
joendoodle
Default 88' won't start... suspect fuel pump...
Acts like lack of fuel (has spark, cranks, but won't fire)
trys to fire on "carb cleaner"
Put in a new fuel filter, no change (someday I'll have a car lift, I'm getting too old to lay on my back)
bought a fuel pressure gauge,
comes right up to 10 psi and no more .....not the 45-47 psi I had hoped for... looks like I'm going in the tank to pull the fuel pump and check it and the inlet screen / filter..
If this sounds logical / illogical let me know...
THANX in advance
The 88 has a sibling
Old Jul 18, 2015 | 09:09 PM
antfarmer2's Avatar
antfarmer2
Sounds right easyest fuel pump to pull
Old Jul 19, 2015 | 08:39 AM
WW7's Avatar
WW7
It sounds like the fuel pump......Racetronics makes a kit to replace the fuel pump , pulsator replacement hose, wiring, tank top gasket, new bolts, and fuel intake sock for around $100.00..This is the best deal, and it's a good idea to change the wire harness to the pump anyway..The C4 Corvette is one of the easiest cars to change the fuel pump in, should only take about an 1 to 1 1/2 hours for a first timer...WW
Old Jul 19, 2015 | 10:22 AM
joendoodle's Avatar
joendoodle
put the pressure gauge directly on the pump discharge 11 psi..
Fuel pumps out....the suction strainer sock is ripped...
Now to get the new one..
Old Jul 19, 2015 | 12:04 PM
joendoodle's Avatar
joendoodle
The good news... new (fuel) pump in 40 psi at the fuel rail.
sputters like she want s to start but no..
past noon and it is over 85... any touching of the Vette(s) will be driving the C-5 today...
the 88 will have to wait...
I'm figuring injectors aren't right / clogging..
Question do the injectors fire in sequence or all @ once???
Old Jul 19, 2015 | 12:35 PM
antfarmer2's Avatar
antfarmer2
Pump it up and see how long it holds. Then pump it up and clamp off the fuel line on top of the tank and see how long it holds. Pull the vaccume line off the fpr and see if you smell gas. I believe yours is batch fire.
Old Jul 19, 2015 | 02:32 PM
joendoodle's Avatar
joendoodle
The pressure holds for a while.... at least 10 minutes, then I took the gauge off. while cranking the pressure pulses. I assumed this was the injectors firing and the pump cycling. dropped to 38 or so in rhythm and immediately recovered.
Thanx for the press reg tip.
Batch fire I'm not familiar with this term.
Old Jul 20, 2015 | 12:46 AM
Cliff Harris's Avatar
Cliff Harris
That means all 8 injectors fire at the same time. That is the setup you have.
Old Jul 20, 2015 | 04:08 AM
joendoodle's Avatar
joendoodle
Thanx... comically I asked that question...
Old Jul 20, 2015 | 11:12 PM
Crash594's Avatar
Crash594
Sounds like the pick up in the distributor is bad.
Old Jul 21, 2015 | 07:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Might be still lots of air in the fuel system.
You can apply 12+ to terminal "G" of the ALCL connector, this will keep the pump running for as long as power is there.
A few minutes should cycle all the air out.
Old Jul 22, 2015 | 05:19 AM
joendoodle's Avatar
joendoodle
Thanx for the tip
Old Jul 22, 2015 | 05:20 AM
joendoodle's Avatar
joendoodle
OK, seems like worth a try before I pull the injectors...
Old Aug 3, 2015 | 09:04 PM
joendoodle's Avatar
joendoodle
Default The update
Kept checking stuff (plug wires etc) gettin spark on all the cylinders...
Finally got her running somewhat.. had to jury rig the throttle linkage to keep her from stalling out. (2000 RPM & working alone)
Listened to the injectors and they are all firing but she had no power (under load)
So before I pull the injectors I gave the "seafoam" a try..
Let her run @ 2000 RPM for about 45 minutes..
filled the tank took her out on the super slab...and she runs like she used to...
THANX for all the help..
===>>> after driving the '03 I forgot how much I missed the raw ride of the C4 w/ Z52 suspension on Michigans roads.
Old Aug 4, 2015 | 09:43 AM
WW7's Avatar
WW7
There are those on here that say Seafoam is snake oil, but I have seen it work to many times with my "own eyes" to let them get away with that statement and always correct them......Glad to hear you got it fixed.......WW. .
Old Aug 4, 2015 | 09:34 PM
joendoodle's Avatar
joendoodle
Thanx...Now that she is "running" great it was a worthwhile and learning experience. I consider working on my cars myself: therapy
To 88' won't start... suspect fuel pump...
