Fuel Pump Voltage
Old Jul 25, 2015 | 02:41 PM
XtremeTuning's Avatar
XtremeTuning
Default Fuel Pump Voltage
I have a modified '88 coupe that seems to be having some fuel related issues. I have a fuel pressure gauge on an aftermarket fuel pressure regulator up front.
It usually reads 40-45psi at idle or when the pump primes the system prior to starting. I've had an issue where sometimes the fuel pump doesn't prime the system. Everything else is working.
The fuel pump setup is the stock in tank pump with a booster pump mounted just outside of the tank at the rear of the car. It appears to be powered off of the same small wires that powers the stock pump.
When the pump primed the system (engine off), it was only getting about 9.5V ... and about 10-10.5V with the engine running.
QUESTIONS:
Is this normal?
It seems low to me. Probably a voltage drop issue. If so, would 8-10 gauge from the battery be sufficient?
The only other thing that could be happening is that one or both pumps is going bad.
What do you think?
Thanks,
-JRW
Old Jul 26, 2015 | 12:39 AM
Cliff Harris's Avatar
Cliff Harris
The power for the fuel pump comes from the fuel pump relay. You might have dirty contacts inside the relay or a poor connection in the wiring.
Old Jul 26, 2015 | 10:03 AM
WVZR-1's Avatar
WVZR-1
I don't quite understand your "tandem" install of the fuel pumps. Seems quite restrictive I'd think regardless of the voltage you supply to them.
You do need to sort the power (12V) and the wiring but I'd think the entire fuel system needs maybe rethought. Perhaps I'm missing something here but you've actually supplied limited information so .........
If both pumps are running from the single source of power wiring there's no doubt you'll have issues.
Old Jul 29, 2015 | 10:32 AM
XtremeTuning
I ended up running a separate 12awg to a new relay and everything seems to be fine. My guess is that the stock 16awg wiring is not large enough to support the larger fuel pump.
Will post back if I run into further issues.
-JRW
Old Aug 5, 2015 | 01:17 AM
eguyett1985's Avatar
eguyett1985
That is pretty typical. I installed this kit from Racetronix and it raised the voltage back at the pump to alternator output voltage.
http://www.racetronix.biz/itemdesc.a...%2D013&eq=&Tp=
To Fuel Pump Voltage
