low front end
Old Jul 27, 2015 | 10:46 AM
shenobi's Avatar
shenobi
Default low front end
I think the previous owner lowered the front of my vette. Is there a quuck way to look and see if anything was done. Anyone have a measurement of the front fender to wheel, mine sits right on top of the tire. The back has a huge gap, is this normal?
Old Jul 27, 2015 | 10:51 AM
antfarmer2's Avatar
antfarmer2
Sounds like it always helps to post the year. And tire size to rule that out
Old Jul 27, 2015 | 10:57 AM
shenobi's Avatar
shenobi
1994 and 255/45/17, i will grab a pic and lunch and post it as well
Old Jul 27, 2015 | 11:14 AM
antfarmer2's Avatar
antfarmer2
Ok I have a 94 too mine is stock and never messed with lowering. But others will know.
Old Jul 27, 2015 | 11:51 AM
BOOT77's Avatar
BOOT77
is it a Z51 car?
Old Jul 27, 2015 | 01:18 PM
c4cruiser's Avatar
c4cruiser
Originally Posted by BOOT77
is it a Z51 car?
The 255/45 front tires means that it didn't come with the optional Z07 performance suspension. That package got 275/40 tires on all 4 corners.
If there is no gap between the top of the tire and the wheelwell opening, chances are that the car was lowered in front using the typical lowering kit that is installed where the spring mounts to the crossmember.
For the rear, check to see if the long spring bolts have a castle nut and cotter pin; that would imply the rear was not lowered. Longer bolts would have to be installed to do that.
Old Jul 27, 2015 | 01:34 PM
shenobi's Avatar
shenobi
It is not a Z51 but does have the FX3 option. I hate the way it is so high in the back. Is it hard to install the lowering bolts?
To low front end
