Fuel Pump
Old Jul 29, 2015 | 08:18 AM
  #61
antfarmer2's Avatar
antfarmer2
Try a noid light on your injectors and a ohm meter should be 12 or over ohms. Test and post your results
Old Jul 29, 2015 | 10:49 AM
  #62
1stVetteFinally's Avatar
1stVetteFinally
Originally Posted by antfarmer2
I would try Cliffs trick.
Ok, I will, but what results would I be looking for?
I'll check them again, but I did check the ohms of the injectors a couple months ago. All 8 were within 13.4-13.6.
Got a fews things to do first, so it'll be a few hours before I can check the injectors and try Cliff's trick. I'll post back with results.
Old Jul 29, 2015 | 10:55 AM
  #63
antfarmer2's Avatar
antfarmer2
With Cliffs trick for it to run.
If the injectors don't ohm as good as they were might have found the problem.
Old Jul 29, 2015 | 11:29 AM
  #64
antfarmer2's Avatar
antfarmer2
If the temp sensor on the water pump is bad I would change that now it can mess with the computer don't get the opti wet!,,,
Old Jul 29, 2015 | 11:46 AM
  #65
5abivt's Avatar
5abivt
fuel rail bolts. pop up the fuel rail and injectors. get 8 paper cups and drop the rail on top with each injector in a cup. prime the fuel pump and go check for leaks.
Old Jul 29, 2015 | 11:59 AM
  #66
1stVetteFinally
For what to run?
The car itself runs. I can drive it without it stalling out or worrying about it not starting. It just doesn't have even close to the power it had before these problems started and it starting giving the 55 code.
Or to keep the fuel pump running like it does to prime the car where it gives 40 PSI on the rail.
If I have the money, I'll replace it also. Otherwise, I will when I get the money. Rent due the middle of next week so....
On the to-do list
Old Jul 29, 2015 | 02:01 PM
  #67
TLS_Addict's Avatar
TLS_Addict
Good luck!
I have an LS3 pump from my Supercharger swap on my C6. Too bad I can't use that. Lol
Old Jul 30, 2015 | 12:13 PM
  #68
1stVetteFinally
checked Ohms on the injectors, 7 were between 13-12.8, one was 2.4. I think I found my problem.
Old Jul 30, 2015 | 01:02 PM
  #69
TLS_Addict's Avatar
TLS_Addict
Nice! After I get my pump changed I need to check mine tonight.
Old Jul 30, 2015 | 01:28 PM
  #70
antfarmer2's Avatar
antfarmer2
Great now unplug that one and fire it up. Geat ahold of John at injection connection and get some bosch 3
Sorry your car was still running my bad
Old Jul 30, 2015 | 05:18 PM
  #71
1stVetteFinally
New fuel injector installed, car is running great. Thank you antfarmer2, TLS_Addict, and everyone else that posted trying to help. I appreciate it greatly.
Old Jul 30, 2015 | 06:10 PM
  #72
TLS_Addict's Avatar
TLS_Addict
Awesome! There is hope yet for me.
Old Jul 30, 2015 | 08:52 PM
  #73
antfarmer2's Avatar
antfarmer2
Old Jul 30, 2015 | 08:53 PM
  #74
antfarmer2's Avatar
antfarmer2
your next
Old Jul 30, 2015 | 09:08 PM
  #75
TLS_Addict's Avatar
TLS_Addict
When it does I am going out to the back of the development and doing a bug *** burn out.
