Fuel Pump
Old Jul 28, 2015 | 08:04 AM
1stVetteFinally's Avatar
1stVetteFinally
Default Fuel Pump
So who makes the best, most reliable replacement fuel pumps for our cars?
I have had fuel pressure issues with my '92 LT1 almost the entire time I have had it. Right now, it will not maintain 40 PSI on the rail. Car is giving a module 4 code 55 trouble code (not enough fuel pressure under acceleration). Turn on ignition, pressure jumps to 40 PSI, but once the pump stops, immediately drops to around 32 PSI, and within 15 seconds, is down to 10 PSI. There are no external fuel leaks and the hose in the pump assembly is in brand new condition. So I'm thinking the pump is leaking fuel back into the tank (what else could it be?). I am tired of screwing around with cheap parts that don't last. So for you Vette owners that have had fuel pressure issues before and have fixed the problem, what pumps are you using?
BTW, I currently have an AirTex pump, which according to my mechanic friend is pure ****.
Old Jul 28, 2015 | 08:40 AM
blackozvet's Avatar
blackozvet
is this the original pump ?
what condition is your regulator in ?
Old Jul 28, 2015 | 09:01 AM
C4vettrn's Avatar
C4vettrn
I would check your pressure regulator first, if you haven't already. Most guys go with a Walbro and Racetronics has good pricing.
Old Jul 28, 2015 | 09:15 AM
1stVetteFinally
pump has been replaced since I bought the car last Sept. Regulator was just replaced since these problems started. Fuel rail holds 40 psi when pump is running for prime.
Pressure has been checked, from OP-
With engine running, 38 PSI on the rail at idle, pressure drops to around 32 PSI as RPMs increase
Old Jul 28, 2015 | 09:34 AM
blackozvet's Avatar
blackozvet
you can test the pressure to see if its going back to the tank by clamping off either the inlet or outlet rubber lines as they come out of the fuel tank, clamp them off just after 'key on -prime the pump'.
Best to get someone to help you do this so you can clamp off quickly before pressure is lost.
Old Jul 28, 2015 | 09:41 AM
1stVetteFinally
ok, so if I understand you correctly, disconnect the return line, turn on ignition (will gas come out the disconnected line?), plug line, watch pressure after pump shuts off. Right?
Old Jul 28, 2015 | 09:49 AM
antfarmer2's Avatar
antfarmer2
Sounds like you got a bad fpr pull the vacumme line off it and smell for gas should be none
Old Jul 28, 2015 | 09:51 AM
1stVetteFinally
never smelled gas there before, but I'll go check just to be sure.
edit: just went and checked for gas smell from vacuum line to fpr, no gas smell
Old Jul 28, 2015 | 10:18 AM
antfarmer2's Avatar
antfarmer2
Then pump it up and clamp off both sides of your fuel line gas is going somewhere. If it does not hold then bad injector of fpr. Did you use the proper hose from the fuel pump to the hard line in the tank? You would know it's about $30 a foot? The cheak valve on the pump may not be that good most are not but should still keep the pressure up while running maybe just a loose clamp on the rubber hose in the tank. Or the wrong hose.
Old Jul 28, 2015 | 10:26 AM
1stVetteFinally
Clamp it off? How? Only way I can think off would involve locking a pair of vise grips down on the soft hose close to where they connect to the hardlines going into the tank. But would that damage the lines?
I used the hose that came with the last pump I bought. Clamps are tight on the hose in the tank
BTW, I appreciate the help
Old Jul 28, 2015 | 10:32 AM
antfarmer2's Avatar
antfarmer2
It could if they are hard and brittle you could pull and plug the return line I believe they are harder to get to then pump it up than use a smooth clamp on the inline to hold it. Or make up a hose with a shut off for the test.
Old Jul 28, 2015 | 10:36 AM
1stVetteFinally
They are soft and bendable. They don't "look" very old tbh. I guess I could use a cloth between the visegrips and hose to make sure they don't get the beginning of a cut
Old Jul 28, 2015 | 10:40 AM
antfarmer2's Avatar
antfarmer2
Ok go get on it and let us know.
Old Jul 28, 2015 | 10:44 AM
WVZR-1's Avatar
WVZR-1
Your "mechanic friend" that was so quick to point out the pump you have as being a piece of **** should understand everything that needs to be done to check for fuel "leak down". If he doesn't well so much maybe for his condemnation of the pump you chose and maybe the "mechanic" tag you hung on him.
Old Jul 28, 2015 | 10:53 AM
1stVetteFinally
will do
He was referring to AirTex fuel pumps in general. From what I have read from customer reviews of AirTex pumps, they aren't the best when it comes to reliability.
Cheap part= you get what you pay for
Old Jul 28, 2015 | 11:12 AM
WVZR-1's Avatar
WVZR-1
Well you've not mentioned the fuel filter condition or the strainer in the tank. Fuel filter can certainly allow full pressure at start up and could certainly diminish at run like you mention, Is the filter mounted maybe backwards? The sock in the tank?
A check valve failure in the pump is certainly a maybe BUT if you purchased local it should be a simple matter of claiming failure. Purchased elsewhere it could be maybe more difficult.
If purchased local what other branding does the store offer? What do they recommend instead of your choice?
Old Jul 28, 2015 | 11:29 AM
antfarmer2's Avatar
antfarmer2
I just took that for granted that filters were done.
To Fuel Pump
Old Jul 28, 2015 | 11:52 AM
1stVetteFinally
Filter has been replaced in the last 6 months. Strainer was new with my current pump.
Old Jul 28, 2015 | 12:07 PM
antfarmer2's Avatar
antfarmer2
Great I thought you were working on the car not getting it done playing on the puter.
Old Jul 28, 2015 | 12:08 PM
1stVetteFinally
Holding 44 psi
