rapidfire plugs have incorrect pre-set gap?
Old Aug 20, 2002 | 05:23 PM
tpivette89's Avatar
tpivette89
Default rapidfire plugs have incorrect pre-set gap?
i just purchased a set of Delco Rapidfire plugs and noticed they were pre-gapped from the facotry at .045. now, in many publications, as well as on this forum, i have been informed that the correct gap for my engine is .035. so which is right? should i leave the gap as is, or reduce it to factory specs? thanks in advance
Old Aug 20, 2002 | 05:25 PM
scorp508's Avatar
scorp508
I have regapped mine to 0.035"
Old Aug 20, 2002 | 08:57 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: rapidfire plugs have incorrect pre-set gap? (tpivette89)
If you want more power, gap at .050 but be prepared for lower mileage and shorter plug life.
.035 is the opposite and .045 is a nice compromise
Jack
Old Aug 20, 2002 | 09:03 PM
65Z01's Avatar
65Z01
The gap depends on the ignition voltage and cylinder pressure. For stock ignition, etc. use stock gap.
Old Aug 20, 2002 | 10:12 PM
lspalding's Avatar
lspalding
Leave 'em the way they are. They're supposed to be at .045. (I have them, they work well.)
Old Aug 20, 2002 | 11:22 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
St. Jude Donor '12
THats funny the ones I bought at the beginning of July were pre gapped at .035. When I cut them back I gapped to .040 (split the diference between .035 and .045) not had any problems, fuel econmy is the same (unless my foot is in the motor). I did replace the coil, cap, rotor and wires as well.
Old Aug 21, 2002 | 12:18 AM
Triple Black 88's Avatar
Triple Black 88
I tried the rapidfires, and after much debate, I ended up leaving them at .045. I have a stock ignition, and they made the car run and idle rough. I ditched them and put the AC Delco "Cut Plugs" gapped at .035 back in and whalah!!! Judging by all of the different opinions, I'd suggest trying them for a few weeks, then either re-gap to .035 or try the "Cut Plugs". Its a PITA to keep changing them, but believe me the gap does make a difference, and it will be worth it in the end. Keep Tweekin'!!!
:flag
Old Aug 21, 2002 | 02:20 AM
ZBRA's Avatar
ZBRA
Default Re: rapidfire plugs have incorrect pre-set gap? (Triple Black 88)
The new Rapidfires are not pre-gapped The first generation of rapidfires were pregapped. In the last year, those have been slowly replaced with the second generation rapidfires. The 2nd gens are platinum and are not pregapped. You will need to regap them to stock specs.
To find out which ones you have, read the back of the box. If it says not to gap and that they are set from the factory, then they are first generation rapidfires. If it says to regap to OEM specs, then they are second gens. There was a redisign in the tips too.
This change over has been going on for quite some time. However, due to the low sales of high dollar spark plugs, there are plenty of first gen rapidfires still in the parts stores.
Old Aug 21, 2002 | 11:15 AM
Triple Black 88
Default Re: rapidfire plugs have incorrect pre-set gap? (ZBRA)
ZBRA, the box I had definitly said to Re-gap to OEM specs, but I didn't because that's what it said on their website's Q & A, plus it seemed to be the majority vote in my post. O well, I am happy with the Cut Plugs. When they wear out, I'll gap and try the rapidfires again.
Thanks for the info! :flag
To rapidfire plugs have incorrect pre-set gap?
