91 Coupe Brake light issue
Old Aug 3, 2015 | 07:21 PM
GGattorr's Avatar
GGattorr
Cruising
Default 91 Coupe Brake light issue
Hey Everyone, I have found some helpful info so far but need some more help if possible.
My 4 round tail lights do no come on when I brake. The running lights, turn signals, flashers, and 3rd brake light all work as should.
There seem to be 2 switches connected to the brake pedal. Attached is a picture of one of the switches. I tested this and the center is constant hot and the two outside ones energize when the brake pedal is depressed. Am I correct in assuming that the brake switch is functioning properly and the problem lies on the way to the rear brake lights? Since all other functions of the tail lights are working, any ideas on where to start looking?
Old Aug 3, 2015 | 08:11 PM
antfarmer2's Avatar
antfarmer2
I believe there is a gound you can find behind the licence plate
