cut spark plug tips?
Old Aug 20, 2002 | 06:00 PM
guywade's Avatar
guywade
Default cut spark plug tips?
what does one look like , can someone post a picture or diagram explaining, where the tip is cut and how you remeasure the gap width from , where to where? TIA :cheers: :D
Old Aug 20, 2002 | 06:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: cut spark plug tips? (guywade)
There's a pic/diagram on my site with instructions.
I measure gap from the edge of the ground electrode to the edge of the center one.
Old Aug 20, 2002 | 06:40 PM
Lone Ranger's Avatar
Lone Ranger
I think you need to have a hotter-than-stock ignition coil on the motor for this mod to work well, no? Or will a stock coil still do the job okay if using the stock gap on the cutbacks?
Old Aug 20, 2002 | 06:54 PM
65Z01's Avatar
65Z01
Default Re: cut spark plug tips? (Lone Ranger)
Though I've always upgraded the coil and wires along with the mod, the references only mention 8-10hp gain from the cut-back mod.
So, I think it would work with stock gap; the unshrouding principle is the same.
Old Aug 20, 2002 | 07:03 PM
VetteNoob's Avatar
VetteNoob
Did it to mine (stock ignition components). Didnt notice a power gain, but gas mileage has improved some.
Old Aug 20, 2002 | 07:22 PM
guywade's Avatar
guywade
Default Re: cut spark plug tips? (VetteNoob)
thats a good enough reason !! :D :)
Old Aug 20, 2002 | 08:07 PM
Mad AUSSIE's Avatar
Mad AUSSIE
in the uk you can buy a plug with 3 bars bent over the electrode and the spark shoots out 3 ways very good , you can use them with standard systems or you can the f1 type plugs with no bar just electrode downside with these is cost, upgrade in system and tends to run hot, if i can find some i will post pics. :cheers: :cool:
Old Aug 21, 2002 | 10:39 AM
black85's Avatar
black85
Default Re: cut spark plug tips? (Mad AUSSIE)
Has anyone ever tried those copper Bosch 3 tip plugs in a vette? I think that is what Mad Aussie is talking about. I didn't know they even existed, but my brother got a set for his 944 turbo (you shouldn't put platnums in a turbo). Supposedly, this would eliminate the need to index or cut back the electrodes. Even if they cost a little more, cutting back the electrodes takes up time (of which I have little). Also, they are much beefier than the +4s.
I just bought a new set of NGK's, but I'm going see if they sell these Bosch plugs in our size/heat range.
Old Aug 21, 2002 | 11:01 AM
lead_foot's Avatar
lead_foot
Default Re: cut spark plug tips? (65Z01)
What tool do you use to actually make the cut?
Old Aug 21, 2002 | 11:52 AM
Guest
Guest
Posts: n/a
Default Re: cut spark plug tips? (lead_foot)
Champoin actually sells a pre cut plug, i cant remember the series, but it is a race type plug,,,,if you want the easy way out get some of those...........
To cut spark plug tips?
