anyone experience creating a cam sensor for sequential injection?
Old Aug 5, 2015 | 05:45 PM
bogor's Avatar
bogor
Made my own crank trigger and cam sensor for my Autronic sequential system
modified large size HEI Dizzy
Used a 2AV54 hall sensor (can be seen in the pic).
The crank trigger use a GT101 hall sensor.
OEM L98 crank pulley modified with four studs 90 degrees apart.
Been working flawlessly
Old Aug 5, 2015 | 07:10 PM
rithsleeper's Avatar
rithsleeper
Bogor, I'm not following what exactly is happening in your pictures. The first one is the base of the housing I take it? What is the braided ground strap for? Did you do something here?
I see the hall sensor but where is the trigger wheel?
Is the trigger wheel your pulley? Did you weld those pieces of metal at the 90* marks? So did you basically make the 4 point trigger and it acts essentially the same as the 4 point on the vortec stock system? Or is yours better in some way?
Old Aug 6, 2015 | 05:13 PM
bogor's Avatar
bogor
The trigger wheel is actially visible in the pic, its the "window" that trigger so its kind of the reverse vs the vortech. Its a little difficult explaining in words but if you are interested I can take some more pics.
About the cranktrigger, Im not familiar with the vortech version but the Hall sensor was supplied with the ecu so I used it. Also, the hall sensor is quite tolerant vs interefence alot better than inductive ones like the one in the crank trigger By MSD.
The 4 metal pieces are just bolted to the pulley. Used small allen bolts and loctite. One stud must be positioned around 60 degrees BTDC and position of theother three are therefore given. I ended up att 55 degrees but I can compensae for this in the Autronic software.
Old Aug 6, 2015 | 05:19 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
For the earlier cars, why not start with a belt drive for the camshaft
The trigger wheel can then be bolted to the outside
http://www.summitracing.com/parts/je...2000/overview/
http://www.summitracing.com/parts/cca-6100/overview/
Old Aug 6, 2015 | 09:39 PM
rithsleeper
Lol $1000 and $500. The belt idea would be cool but not at that price. Thanks for the info that that exists though. Very interesting.
I would appreciate a few more pics if you could bogor. I see what you are saying with the window being the trigger.
At this point I'm leaning toward a trigger wheel and spacers from dyi and using a hall sensor on the timing cover. I can fab a mount easily. Then the vortec seems the most promising if I can still use my 8 pin module and just take the trigger from the vortec. Then I guess someone will get a hell of a deal on purchasing my brand new Msd HEI distributor....
I want to keep my Msd but at this point financially might work out better to sell it and buy a GM vortec distributor....
Old Aug 6, 2015 | 10:48 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Just checked pricing; PICK 'N PULL (down the hill in SLC) sells "electronic distributors" for $34.99.
I always love a trip to P'nP, if you need help getting one for cheap.
Old Aug 9, 2015 | 02:24 PM
bogor's Avatar
bogor
The trigger Wheel is originally from my old wall mounted tool holder-basically a tin can...cost about zero
Only cost was the sensor (about $40)
not a very pretty design but it works!
Old Aug 10, 2015 | 08:18 PM
rithsleeper
Very impressive. You are right, doesn't look pretty . Gives me more things to ponder while the engine is still being machined.
Old Aug 10, 2015 | 11:11 PM
SpedRacr93's Avatar
SpedRacr93
https://www.eficonnection.com/eficon...spx?ItemId=623
-OR-
https://www.eficonnection.com/eficon...px?ItemId=1183
will both get you there...
As a few other guys said, you can also do dual sync distributors and not bother with the crank trigger fab work.
Old Aug 11, 2015 | 12:03 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
-OR-
Is it just me...or is that a $125 and $315 version of the $39 Vortec distributor that I posted above...w/o the cap and rotor?
Old Aug 11, 2015 | 12:33 AM
SpedRacr93's Avatar
SpedRacr93
The design is the same, but the ones I posted are not made from plastic. Cheaper one is cast aluminum and the other is machined from billet.
Old Aug 11, 2015 | 10:33 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Huh. I see what you're saying. Though, I can't imagine why you'd need a billet unit (other than for bling). I have a Silverado (w/a Vortec) motor, currently has 270,0000 miles on it and I've not yet had a broken down distributor.
Old Aug 11, 2015 | 10:50 PM
  #33
SpedRacr93's Avatar
SpedRacr93
My old '97 Z71 got a crack in it around 240,000 and gave me troubles for the longest time which is why I won't mess with a plastic distributor again. I loved that truck for it's simplicity, but GM did the worst job on designing a fuel pump for that vehicle. I replaced it at least 8 times in the 10 years I owned it. I drove it to 280,000 before selling it to my nephew.
Some turd stole it from a Best Buy parking lot within a few months of him driving it...
Old Aug 11, 2015 | 11:27 PM
  #34
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yeah...what is the deal w/those pumps?? I've changed mine 4 or 5 times now, and the fleet trucks I used to manage, we changed them ALL the time. Didn't really matter what brand is used either...the don't last. I don't "get it", why a pump in my 'Vette lasts and lasts...and the same pump (looks the same) doesn't live in the truck. Weird. You're right though...they failure prone.
Old May 23, 2023 | 10:32 AM
  #35
1971corvette's Avatar
1971corvette
The stock distributor in the L31 "Vortec" truck motor is a 180* ("one tooth") cam sensor. Could you grab one of those from a junk yard and use that?
These are junk in my opinion, seems the contacts inside are routed so close on the #5 that they burn thru and start arcing causing a misfire.
I have a 2001 chevy express 3500 that eats caps, currently trying an Accel cap to see if it lasts any longer, I don't have high hopes as it is made in china
So any other ideas to grab a cam signal ?
I have a MSD mechanical 8572 & 6AL = yes I'm keeping the mechanical tach
Old May 23, 2023 | 10:40 AM
  #36
1971corvette
WOW what a simple idea, I think this is exactly what I am looking for, I've been looking & looking = damn such a simple solution, gotta go, headed out to the garage to tinker
on the lathe & mill now.
I just happen to have a RCD Engineering belt setup
Old Jun 1, 2023 | 06:46 PM
  #37
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Did you miss my post above where I mentioned that mine had lasted over 270k? By the time I sold the thing it had 300k. Distributor never faltered. ID even K if I ever changed the cap on the thing!
To anyone experience creating a cam sensor for sequential injection?
Old Jun 4, 2023 | 12:32 PM
  #38
auburn2's Avatar
auburn2
Buick made a cam sensor for the Gran National that fit into the distributor hole. You might be able to repurpose that. I think you can still find them from some of the GN aftermarket.
Failing that you have some options like this:
https://www.jegs.com/i/MSD+Ignition/...SABEgLQRfD_BwE
Old Jun 4, 2023 | 01:18 PM
  #39
Bill Chase's Avatar
Bill Chase
yeah, make a blanking cap. just use it for cam sync. convert to coil near plug. if you do that the vortec distributor is very reliable, parts available cheap. or you can spend $297 on the msd #85141. the vortec distributor cap is a known "weak part" cross firing and premature failure was common for them even under warranty. but the sensor, and reluctor are actually quite robust, and megasquirt, as well as efi connection still sell it in their 24x/58x kits. because it is good, readily available, and super cheap.
Old Jun 4, 2023 | 01:32 PM
  #40
Bill Chase's Avatar
Bill Chase
holley 556-114 is made for the jesel, comp, rcd, jones racing belt drives. simply replace one of the cam gear bolts with the one supplied in the kit. it is a flying magnet setup (same as msd 4x crank triggers, just a better effect sensor. the signal is less suceptable to noise. if you plan on keeping your current msd dizzy rotor phasing would be mandatory, and a pain in the rear. In all seriousness if you are going efi the holley #565-200 dual sync distributor or msd #2375 are pretty good. no rotor phasing issues. plug and play with holley efi, easily used with megasquirt or other efi systems. you can also modify your tach drive unit to use a hall effect sensor triggered off a magnet embedded in the shaft similar to the msd 85141 cam sync/oil pump drive unit. keeping the tach drive complicates things.
