Sticky gas pedal
Old Aug 5, 2015 | 06:03 AM
Jackzap's Avatar
Jackzap
Default Sticky gas pedal
My gas pedal sticks from a dead stop. After your moving its is fine. Has anybody had this problem. Thank you for any suggestions
Old Aug 5, 2015 | 05:20 PM
t384's Avatar
t384
Had this problem on my truck once, it was carbon build up around the throttle blade in the throttle body. Hit with some carb cleaner and it was good as new.
Old Aug 6, 2015 | 01:06 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Aug 7, 2015 | 01:00 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I had that problem on a Buick Lesabre. I cleaned the throttle body with some gumout spray carb cleaner. It loosened up the blades and never had another problem.
Good luck.
Old Aug 19, 2015 | 11:27 PM
Jackzap's Avatar
Jackzap
Thank you for the replies. I cleaned the throttle body and it solved the problem
To Sticky gas pedal
