Help-need link to digital dash web page
Old Aug 20, 2002 | 10:45 PM
Mike263's Avatar
Mike263
Default Help-need link to digital dash web page
I lost my link to Batee's pages on the early C4 digital dash. Need wiring diagrams. Anyone have the latest link?
Thanks.
Old Aug 20, 2002 | 10:55 PM
jfb's Avatar
jfb
Default Re: Help-need link to digital dash web page (Mike263)
http://www.batee.com/corvette/derg/c...ematictopmi...
Old Aug 21, 2002 | 12:05 AM
VQT88Vette's Avatar
VQT88Vette
Default Re: Help-need link to digital dash web page (jfb)
Its not working for me:(
Old Aug 21, 2002 | 12:10 AM
VQT88Vette's Avatar
VQT88Vette
Default Re: Help-need link to digital dash web page (VQT88Vette)
This will get to the link :yesnod:
Old Aug 21, 2002 | 08:47 PM
Mike263's Avatar
Mike263
Thanks! That's what I needed.
Now a question for the digital dash experts. My dash goes black every so often. Then it comes back on. When it comes back it displays the startup test ( all LCD's lit) then the normal display. After the black out it comes back with the Avg GPM and Trip reset to zero (memory wiped). When it's black the turn signal indicators and high beam indicator are NOT lit up.
Sounds like a power problem, not a ground problem, right?
Power supply on circuit board? Bad (loose) connector? Where should I go from here?
Old Aug 21, 2002 | 10:09 PM
jfb's Avatar
jfb
You are losing 12v power to the cluster, either the positive 12v line or ground, or both (not likely). Unplugging and replugging all the connectors is a good start to clean the connector contacts. Examine the traces on the circuit boards that carry 12v and ground for hairline cracks with some low power magnification. After this it gets much more complicated and you might consider sending the boards to a repair station.
Old Aug 22, 2002 | 08:49 PM
Mike263's Avatar
Mike263
Thanks. I'm going to checkout the two grounds, 32 pin connector and PC boards this weekend. Hope it's connectors.
Old Aug 28, 2002 | 10:20 PM
Mike263's Avatar
Mike263
Just a followup. Checked grounds and connectors this weekend, Nothing obvious using DMM and wiggling wires around. Cleaned and reseated all connectors. After 3 days of normal use - no problems so far.
To Help-need link to digital dash web page
