spark plug came out
Old Aug 18, 2015 | 11:29 PM
bob arrowsmith's Avatar
bob arrowsmith
Default spark plug
Ok, this is what he did , he had a duel threaded tap, one the size of the original spark plug hole which when inserted into the sloppy threads would set it up for alignment for a straight shot into the hole, once through he kept turning with the same tap and proceeded to tap the newer over size threaded hole for the insert,, will let u know which brand tomorrow. then with a hole camera he was able to go down inside the piston area and check for cut thread remains, either suck them out or blew them out, I do not know but he was able to tell it was clean with the camera,,, great to have the proper tools.
Old Aug 24, 2015 | 07:14 PM
bob arrowsmith
Default blew out spart plug
The part use was a time cert from Autozone....
Old Aug 24, 2015 | 09:03 PM
BOOT77's Avatar
BOOT77
Mine was a kit from a local parts store and it was around 15yrs ago +/-.
Old Aug 25, 2015 | 05:09 AM
WVZR-1's Avatar
WVZR-1
I might have never thought about AZ. The AZ web-site doesn't acknowledge a time-sert search. I've not been in one for quite a while so I might need to drive by.
