Is this the Opti? '94
Old 08-14-2015, 01:22 AM
ricasso
ricasso's Avatar
Default Is this the Opti? '94
After a particularly hard drive on a nice straight road I noticed I had lost a cylinder,I am hoping it is just a plug or wire and not the Opti starting to crap out, its a 94 and does have 71K on it so Im sure some will say its due to go but its fine on the other cylinders, (its on the lefthand bank) no smoke of any colour, it wasnt missing at all up to this point either,so far as I know the plugs and wires could be originals! certainly haven't been changed in the three years I've had the car, any ideas?
Old 08-14-2015, 07:31 AM
TorchTarga94
TorchTarga94's Avatar
If you have for sure narrowed it down to one cylinder not firing, then it is probably just a plug or wire issue. It could be the terminal for that cylinder within the Opti cap but kind of doubtful. You need to narrow it down to which cylinder exactly and then replace that plug and wire.
Old 08-14-2015, 08:07 AM
ricasso
ricasso's Avatar
As soon as it stops raining (24 hours now..) I'll get out there and check it over, and no it wasn't raining when it happened I have a new set of wires that I bought some time ago and a set of plugs on order, hard to find the right plugs here in the UK for some reason, so it seems a good opportunity to freshen it up a bit.
Old 08-14-2015, 10:23 AM
antfarmer2
antfarmer2's Avatar
On my 94 I had to loosen the power steering pump and move it forward to get the wires through make sure you use a bit of dielectric gease on them and make sure they click twice. I had one cylinder stop fireing pulled the plastic cover off and found a injector wire nibbled through. Don't forget the antisize on the plugs.
Old 08-14-2015, 02:18 PM
ricasso
ricasso's Avatar
Very good point, I'll definitely be checking the injectors and wiring, another thing to tick off the list of possible causes..
Old 08-15-2015, 11:00 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Antfarmer2
I think you need a nickname how about "Always Click Twice"
To Is this the Opti? '94
Quick Reply: Is this the Opti? '94
