I have a fairly decent amount of drag racing experience and if the car is in perfect operating condition (meaning everything works), you can start looking at the numbers on your timeslip.
If you want to post your best run, I may be able to tell you where the problem is. For example, on my timeslip, I pulled a 2.1 short time, a 9.5 660 at 74 (first sign something is wrong) then only did 91 in the 1320. Just about every car can add 20mph or more from the 1/8 to 1/4 mark.
60 foot determines ET, that is where you need to concentrate your efforts, if all other factors are equal.
Maybe now I can get a 13, dont you think?
[Modified by Bravery, 11:58 AM 8/21/2002]
13's ? If you don't run in the 12's with longtubes & the converter you got problems -lol
just make sure you figure out & fix your engine problem(s) first.
good luck
Why did you decide to lose the LT1's dual exhaust for a L98 style exhaust? I think that system would be great on a L98, but I think you are taking power away from yourself by brining it all back into 1 CAT and rear Y.
Daaayum that is one slow vette!!! :D In fact......Mikes vette is the SLOWEST vette in the world! hahahahahahahahaha next time out we'll get her to do a better time mike...i hope.
brian
aka (PG) :jester
So you will be running the same rear Y as myself and Vic'89 with our L98s. Indeed that 3 1/2" into dual 3" is an impressive piece.
I dropped 0.3sec off my ET and gained nearly 3mph in trap speed from just front Y, RT cat and TPIS cat-back; Vic also got very good gains from that cat-back.
