Question about Hooker super com. headers
Old Aug 21, 2002 | 01:37 PM
daddydahlin's Avatar
daddydahlin
Default Question about Hooker super com. headers
How hard is it to install an o2 senor to these headers or is it easier to reprogram the computer to bypass the o2 senor?
Old Aug 21, 2002 | 01:41 PM
Flame Red's Avatar
Flame Red
Default Re: Question about Hooker super com. headers (daddydahlin)
When I had my Hookers installed, they welded a new bung on the collector so it can get readings from all the cylinders. Other than that, https://www.corvetteforum.com/techti...D=93&TopicID=2 should give you all the information you need.
Old Aug 21, 2002 | 02:01 PM
daddydahlin
Default Re: Question about Hooker super com. headers (Flame Red)
So the the bung you had welded in was on the collector is that the same place the bung is located on the 2149 headers
Old Aug 21, 2002 | 02:09 PM
gcrouse's Avatar
gcrouse
No the O2 bung on the 2149 headers is on the #7 primary tube only; not a great indicator of the entire engine. I plugged mine and had an exhaust shop drill and weld a new one on the collector. Pretty painless- took 15 minutes.
Old Aug 21, 2002 | 02:13 PM
daddydahlin
Default Re: Question about Hooker super com. headers (gcrouse)
thanks sounds like a pretty easy problem to fix. I'm just trying to learn as much as I can because I will be installing the headers myself
Old Aug 21, 2002 | 02:42 PM
daddydahlin
Default Re: Question about Hooker super com. headers (EIGHTY5)
When you used the reducers did you use the y pipe that hooker makes or did you have one made, because I'm planning on having reducers welded to the y pipe and then have a pipe cut to replace the cat.
Old Aug 21, 2002 | 04:16 PM
daddydahlin
I already have the flowmaster cat-back that I just got 6 months ago so I don't want to go to a true dual set up yet.
Old Aug 21, 2002 | 04:47 PM
silvvette's Avatar
silvvette
that's what I did... "weld in a o2 bung into the collector" and used copper seals between the collector and the new 2.5".
Old Aug 21, 2002 | 04:54 PM
daddydahlin
Default Re: Question about Hooker super com. headers (BluePastU)
thanks everyone for your help :chevy
Old Aug 21, 2002 | 09:55 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Just a kindly reminder. You are supposed to only append your signature to your first post in each thread. Then subsequent posts just un-check the box so we don't have to load your signature picture all those times. Thanks.
Old Aug 21, 2002 | 10:11 PM
Corvette0096's Avatar
Corvette0096
Default Re: Question about Hooker super com. headers (Bob86ZZ4)
Oooooops :bb
Old Aug 22, 2002 | 12:43 PM
Vic'89's Avatar
Vic'89
:lol:
where does it say this in the corvetteforum.com rules & regulations? Although it wasnt me this time, I sometimes do this.......
are you putting in an application to be a moderator?
:confused:
It's just an unwritten forum rule. 1 signature per post.
Vic
Old Aug 22, 2002 | 01:21 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Question about Hooker super com. headers (Vic'89)
Vic is correct. And don't jump all over me. I said it nicely. If you don't believe me then why don't you check with a moderator. There is also a large group of people that don't like it when people put pictures in their signature. That's one of the reasons for only appending your sig once in a thread. It takes too long for people with slow modems. And no, in answer to the question, I don't want to be a moderator. Too many people being snotty sometimes, ahem.
Old Aug 22, 2002 | 01:38 PM
VetteNoob's Avatar
VetteNoob
:confused:
Here you go. This might help some.
http://forums.corvetteforum.com/zero...=345482&page=1
Old Aug 22, 2002 | 03:04 PM
daddydahlin
I'm sorry father for I have sinned
Old Aug 22, 2002 | 03:10 PM
FoolCrzy's Avatar
FoolCrzy
I thought this thread was about headers... :D
Old Aug 22, 2002 | 03:14 PM
daddydahlin
Default Re: Question about Hooker super com. headers (FoolCrzy)
so did I but I get on the computer this afternoon and all I read about is how bad I am because of my sig.
To Question about Hooker super com. headers
Old Aug 22, 2002 | 05:45 PM
ROME's Avatar
ROME
How did we get from headers to footers ;)
Old Aug 22, 2002 | 06:11 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Question about Hooker super com. headers (ROME)
Now all of you go to confession and say the rosary three times for dragging this thread beyond reason.
:yesnod: :yesnod:
Old Aug 23, 2002 | 06:23 AM
JoBy's Avatar
JoBy
Actually the page will not take longer to load if the same picture is shown many times. It will only be loaded once from the web server and duplicated in the web browser. The page will load just as fast if the sig is used 10 times as if it was only used once. There will be more to scroll thru tho ...
And to the headers. I welded a new bung on the collector.
Click to enlarge:
[Modified by JoBy, 11:25 AM 8/23/2002]
