Crossfire idle speed, How to increase?
Old Aug 21, 2002 | 01:40 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Crossfire idle speed, How to increase?
How do I increase the idle speed on my automatic 1984 crossfire corvette?
Any help would be appreciated.
oldace1@earthlink.net
Old Aug 21, 2002 | 02:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Crossfire idle speed, How to increase? (oldace84)
Pick up a Haynes manual as the procedure might be tricky.
I believe there may be some sort of balancing opertion involved on a X-fire.
Old Aug 21, 2002 | 06:52 PM
JonM's Avatar
JonM
You shouldn't have to mess with the idle speed on a crossfire, Its controled by the ECM. Try setting the TPS and clean out the IAC...go here it will show you how to do it.
http://www.crossfire.webhop.net/
Old Aug 21, 2002 | 09:50 PM
RED84CF's Avatar
RED84CF
Why? My crossfire idles around 900 when I first start it up and then comes down to 600 when warmed up. I wouldn't want it to idle at 900 all the time.
I have an automatic also. At 900 I would have to really mash the brake to keep it from creeping forward when stopped. It idles smooth and the flowmasters sound great at 600. Just my opinion.
Old Aug 22, 2002 | 12:52 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: Crossfire idle speed, How to increase? (JonM)
put in a 383 stroker! :jester :p: no seriously TPS will change idle. :yesnod: good luck.
Old Aug 23, 2002 | 08:42 PM
oldace84's Avatar
oldace84
Default Re: Crossfire idle speed, How to increase? (RED84CF)
THANKS FOR THE REPLY..
REASON WHY..
I put on march pulleys....also installed a true stuff altenator 140AMP.
But still when the car warms up..and I put on the radio, or air conditioner,
and then apply brakes charge goes int red zon 11.4volts on dash..
that is why I thought if I increase the idle higher it would help...even when I hit the brakes the voltage drops...let alone trying to use the radio....
I have installed MSD coil....K&N FILTER....FLOWMASTERS....ETC.ETC..ETC...
what do you think
thanks
oldace1@earthlink.net :confused:
Old Aug 23, 2002 | 08:46 PM
oldace84's Avatar
oldace84
Thank you
but what is a TPS OR IAC Cleanout?????
Old Aug 23, 2002 | 10:09 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
High amperage alternators "in general" do not pruduce as much current at idle as stock.
Loose the alternator and get your old stock rebuilt at a local shop.
Old Aug 23, 2002 | 10:20 PM
JonM's Avatar
JonM
Thank you
TPS= Throddle Posision Sensor
IAC= Idel Air Control
Make sure you check this site out under TECH and FAQ
Old Aug 24, 2002 | 02:10 AM
oldace84's Avatar
oldace84
Removed the March Pulleys...everything OK....NOW....
MISS USING THE PULLEYS THOUGH....this was 2 set....crank and altenator...
car even runs cooler...
oh well..
thanks for the help ....
oldace1@earthlink.net :rolleyes:
Old Aug 24, 2002 | 06:44 PM
RED84CF's Avatar
RED84CF
Glad to hear you got that problem resolved.
To Crossfire idle speed, How to increase?
