Will I need new chip?
tunerpro rt software, you will need the files and bin for the 89.
Then you can make changes on the go, no need to remove replace chip once you have connected the ostrich to the ecm.
visit the scan and tune section for info and tips.
You will need the 89 Y body edf and ads files, see links below.
http://www.tunerpro.net/
http://www.tunerpro.net/downloadBins.htm
http://www.tunerpro.net/download/bindefs/GM/6E.xdf
http://www.tunerpro.net/download/dat...1227165_6E.ads
Save your stock chip settings, this is a must I always have a spare chip to go back to if I have stuffed something up.
Some find it a steep learning curve, others can understand it well after some research.
For headers and mild cam you should be right with the standard setup, the ecm will adapt the engine management.
A wild cam will need idle speed changes etc.
or changing to 383 needing maf modifications, you can adjust so many things like advance curves.
Go for it but be careful and write down what changes you have made where..
