85 Starts then dies 2 secs. later cleaned gas tank
cleaned sending unit
new tune up
new fuel filter 8-15-15
new pick up coil for distributor
new iavc
new throttle body gasket
new the maf sensor
brand new radiator
new thermostat and gasket
new relay for cooling fan
any one have same problem
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
new tune up
new iavc
new the maf sensor
brand new radiator
first thing you should have done before spending $$$$ on anything is to determine if you are lacking spark or fuel when it dies
- start with the basics. did you run a basic fuel pressure test? my first guess, and this is A GUESS, but it sounds like a fuel problem - maybe a fuel pump or FPR
fuel pressure test ok. fuel at start up 45psi and when running 40 to 42
