help! '91 no start
Old Sep 7, 2015 | 05:37 PM
L98 DRIVER's Avatar
L98 DRIVER
Default help! '91 no start
my 91 6sp has sat in storage for about 5 years and now no start.
had vats issue that is now fixed had 1 Injector out of spec. now replaced.
drained and replaced fuel. It will run with happy juice up her snout. no codes in pcm or ccm. node light flashes during cranking at each injector.
good fuel pressure at the rail. injector ground is at 0.1 ome from ecm connector to battery ground any body got ideas?
Old Sep 7, 2015 | 05:59 PM
QZRBLU's Avatar
QZRBLU
2017 C4 of Year Finalist
Dave,
The next thing I would do is replace all 8 injectors with Bosch III's from Jon at FIC https://secure.fuelinjectorconnectio...il-orings.html. I'd be willing to bet your originals are gummed-up and sealed at the tips. 5 years in storage can cause a LOT of damage. I assume they are original Multecs?
Mick
Old Sep 7, 2015 | 07:12 PM
Christi@n's Avatar
Christi@n
Last week my car was cranking but not starting was battery 10,39 dcv, is your ok?
Old Sep 7, 2015 | 07:27 PM
L98 DRIVER's Avatar
L98 DRIVER
injectors and owner are originals. battery is not, it is at 12.5V
Old Sep 7, 2015 | 07:58 PM
Christi@n's Avatar
Christi@n
Surely battery is good condition
Old Sep 8, 2015 | 05:48 PM
L98 DRIVER's Avatar
L98 DRIVER
Originally Posted by QZRBLU
Dave,
Mick
Any other ideas before I pull the trigger on some new injectors?
What say you my panel of experts
Old Sep 8, 2015 | 06:19 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yes. Check your fuel pressure, before you replace injectors.
Old Sep 8, 2015 | 06:26 PM
Christi@n's Avatar
Christi@n
The chepest thing you can try to replace is the coil...there is ICM too
Old Sep 8, 2015 | 06:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Noooo....the CHEAPEST thing you can do is diagnose the problem.
Especially in this case, the OP stated in the first post:
That means that it has spark, and randomly buying ICM's and Coils would be a complete waste of money. That the car runs on ether, shows us that it has spark...problem is lack of fuel.
OP should check his fuel pressure.
Old Sep 8, 2015 | 07:11 PM
Christi@n's Avatar
Christi@n
Excuseme guys i didn't really understand that "t will run with happy juice up her snout" meant to have spark
This case no need coil
Old Sep 8, 2015 | 10:34 PM
Cliff Harris's Avatar
Cliff Harris
"happy juice" is starting fluid. If the engine runs when starting fluid is sprayed into the intake then the ignition system is OK.
Old Sep 9, 2015 | 06:02 AM
Christi@n's Avatar
Christi@n
Got it
Thank you
Old Sep 9, 2015 | 11:09 AM
Vic'89's Avatar
Vic'89
I would pull a few of the spark plugs out and see if they wet or dry.
If dry and the noid light is flashing , then the injector is gummed up and not opening.
I had this issue with 2 injectors.
Vic
Old Sep 13, 2015 | 09:14 AM
woody41's Avatar
woody41
My 91 had same type issue cranked but no start. Went thru ignition system all new parts, went thru fuel system (new injectors from FIC) still no change, all new sensors still no start. Ended up being a clogged catalytic convertor. Replace with new Y pipe and single high flow cat. Between this and all new ignition/fuel system runs great. Mine had sat for about 3 years in original owners garage, 77,000 miles.
To help! '91 no start
