Power Antenna replacement
Old Aug 23, 2002 | 01:33 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Power Antenna replacement
What a kissing bitch!
The service manual left out a few steps.
Like removing the left rear wheel and wheelwell makes the antenna much more accessible.
Also, I tied a string to the antenna wires, so when I pulled them through the body hole, I was able to pull the new ones through.
Once I knew what I was doing, took me all of 5 minutes to reinstall the new one and another 5 minutes to put the luggage shade and trim pieces back.
Hard when you have to lay on your back to do this.
But, all is well now.
Old Aug 23, 2002 | 01:43 AM
tacblu's Avatar
tacblu
Default Re: Power Antenna replacement (Mr Mojo)
Yeah, I've been there, done that! What a pain. I can't wait until I have to replace an outer tail light bulb in my '86.
Old Aug 23, 2002 | 02:58 AM
GM_96LT4's Avatar
GM_96LT4
Same here,
At first, I just wanted to replace the mast, but everyone tells you that you should open the base to check for the broken piece. The antenna didn't have any screws or bolts, just plastic rivets (if that is correct) and I mutilated it taking it off and even more so trying to put it back together.
To make a long story short (and I know, too late) It took just as much work, and I still ended putting a new one in.
Glenn
Old Aug 23, 2002 | 03:07 AM
1bad85's Avatar
1bad85
From: livin life one hold my beer moment at a time Houst Tx
Default Re: Power Antenna replacement (GM_96LT4)
where did you guys get your replacements? Mine needs one and im tired of looking at it up all the time.
Old Aug 23, 2002 | 03:16 AM
GM_96LT4's Avatar
GM_96LT4
Default Re: Power Antenna replacement (1bad85)
1bad85
I bought my mast from Mid-America and the whole assembly from the forum mall. I believe it was from ZIP. They give a 5% discount for being a member.
Glenn
Old Aug 23, 2002 | 08:48 AM
Mr Mojo's Avatar
Mr Mojo
Got mine from The Last Detail $88 + shipping.
www.tld-corvette.com
Old Aug 24, 2002 | 12:35 AM
SLEV89's Avatar
SLEV89
even GM sells it for a reasonable price - mine was $15 or so
my '89 was a cinch (?!?) guess i was holding my mouth just right.
also, it had screws holding the case together so removing the broken bits and gunk buildup was no prob.
i serviced it on a dairy case beside the vehicle while the wires were still attached (except for the ground wire).
Old Aug 24, 2002 | 12:50 AM
lampedusa's Avatar
lampedusa
I think that my motor still works, but I'm unsure as to whether or no I need to replace the entire motor, or just the antenna mast... I think just the mast because it stays up, and I can hear the motor churning, and sometimes the mast goes down.
Old Aug 24, 2002 | 12:53 AM
SLEV89's Avatar
SLEV89
Default Re: Power Antenna replacement (lampedusa)
lampedusa - i'd say your mast is broken - just like the thousands of others - especially if you can manipulate it up and down by hand.
Old Aug 24, 2002 | 12:57 AM
lampedusa's Avatar
lampedusa
Default Re: Power Antenna replacement (SLEV89)
So you do not think I need to replace the whole motor too? Can you email me the steps you took to fix this? gerken24@yahoo.com
Old Aug 24, 2002 | 01:02 AM
Utahvette's Avatar
Utahvette
just replaced the mast on my 94, piece of cake one the easiest things ive done on that thing. :lol:
Old Aug 24, 2002 | 01:58 AM
republicanhunk's Avatar
republicanhunk
i bought my replacement at autozone. i wouldnt suggest anyone buying theirs there because not only do i have a mount sticking through the body, i have an antenna that gets me accuse of being affiliated with nasa. i mean this thing is 5 fet tall. :)
Old Aug 24, 2002 | 02:25 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
Car lift? :D
Old Aug 24, 2002 | 02:31 AM
1bad85's Avatar
1bad85
Default Re: Power Antenna replacement (X-FireChance)
well im not quite sure whats wrong with mine. But I do know that the previous owner cut the wires. wonder why he would do such a thing?
Old Aug 24, 2002 | 02:42 AM
GM_96LT4's Avatar
GM_96LT4
He probably tried to fix it himself and didn't realize you have to go through the hatch to reach the wires disconnect.
At first, I didn't realize you had to do it until I had my hand all the way up following the wires and felt the little hole going into the body. Just a guess.
Glenn
Old Aug 24, 2002 | 02:55 AM
Mr Mojo's Avatar
Mr Mojo
I just found out that if you go to a dealer for a replacement, they now have a generic replacement. Instead of unplugging teh old wires and plugging in the new, you now have to splice the new wires in.
Old Aug 24, 2002 | 06:59 PM
robert kirk's Avatar
robert kirk
i just finished doing mine about 30 min ago, i did it just like slev89 did his. no problems at all took about anhour. robert
Old Aug 24, 2002 | 08:14 PM
cprgmr's Avatar
cprgmr
Yep, been there and done that one. The only problem I ran into was the mouth full of dirt and debris that came falling out of the fender when I was under there... :cry
Old Aug 25, 2002 | 06:47 AM
JP's C4's Avatar
JP's C4
I can only imagine that he couldn't find the connectors in the back. When the antenna mast cable is broken the antenna motor runs until the antenna is up or your battery is empty. Cutting the wires is a little drastic, i gues.
To Power Antenna replacement
