optis suck!
Thx.
Thx.
(Though i can share with others misery on the optispark)
After so many years working on aftermarket parts, DIY, and this forum I have learned (the hard way) the best electrical components are the factory products.
I got lucky with the MSD optis on Betty Boop, and The Ghost, but many in here claim to have issues with them.
The only small thing I can advice you is to disconnect the battery for few minutes, and try again. If that doesnt work buy a GM opti-spark ( buy the vented one). If this doesnt fix it, you have another issue, and that would be a new thread.
Good luck
I believe he stated that petris was rude to him also, threatening legal action, collections (after the guy disputed gettig a defective optispark via his credit card).
If there is an issue with the quality of these new non - mitsubishi optical sensor optisparks that they are using, then petris should be kissing everyones butt and not be rude about it.
He doeSnt reimburse you for your labor so i dont know what the attitude problem is.
Good luck
In 2001, i paid $600 (dealer markup) for just the base (cap/rotor not included) from a chevy dealer. It was an ac delco new old stock for my 93. I added a gen 2 cap and vented harness (using one of the 3 weep holes for the other vac line).
Sometimes if you search ebay you will find an old NOS one that some hobbyist took off an lt1/4 crate motor or someone had bought years ago as a spare.
Be prepared to ask a lot of question to the seller and expect to pay close to $500 for the real deal.
Can add a custom vent to it yourself
I think this forum may agree that a vented opti will survive longer than an unvented opti.
Again, no dispute, just curious as to why you are recommending very old technology?
Here is what i think happened in hour case:
I believe you had the dealer install an ac delco 'remanufactured' optispark. These are not the same as new old stock optispArks. In china, they do a great job replacing bearings and seals, unfortunately they do NOT replace the mitsubishi opticAl sensor which is they heart of the unit - however they do spraypaint the optical sensor black to make it look shiny and new (kind of like how they spraypaint fruits and vegetables in their markets to make them look more appetizing.....)
Heres my Experience:
The last time i looked for an optispark (in 2012), i was horrified to find that all the ac delco new old stock was gone. (For 92 thru 94 style.).
I ended up converting my cam/ timing gear to a gen 2 style.
I bought an ac delco remanufactured gen 2 optispark. It would start up and run for about 3 minutes then die. It would not restart until the car cooled completely, about 6 hours later.
When i took it apart was when i found that they had 'recycled' the mitsubishi optical sensor from a previous unit and painted it black.
Whatever test they perform on the sensor (if they do one) probably was done when the sensor was cold so the problem didnt show up.
-or-
Perhaps the coat of paint they put on the optical sensor contaminated something
I dont know what caused the original mitsubishi optical sensor to fail. Whether it was broke before the rebuild process or whether it got broke during the rebuild process (ie. The coat of paint)
I feel the frustration here. Its a PITA, have to go back in and change it all back out.
This is why i do my research and am willing to pay a little more to find an oem nos non rebuilt working optispark.
Also, if your car is a 92 thru 94, you need to rtv the 2 halves of the optispark (as a backup in case the seals crack) and add a vent harness or you may be doomed to the same failure.
This really is a case of 'they dont build them like they used to'
What is 24x? What is involved. Thanks
Take it apart, check it out (look for rust, moisture intrusion, bearing wobble, etc,) and if its still good I recommend just replacing cap / rotor and adding a gen 2 optispark vent harness (use late model cap which has one of the vent harness fittings and then use one of the 3 weepholes as the other fitting... obviously block off the other 2 weepholes and put a bead of RTV silicone around the optispark to keep moisture out - should the perimeter seal crack/ fail)
The other nipple is what you use one of the 3 weep holes for (drill one of them out to 1/8? I think and epoxy in a 1/8 straight vacuum connector to use that as the 2nd nipple. Obviously then you need to block off the remaining 2 weep holes).
The gen 2 opti base part has the 2nd nipple but you cant use that be ause the drive shaft is different)
Do buy the gen 2 vented harness becaus it includes a flow reducer and check valve on it.
The other ends of the hoses connect up to a manifold vacuum source (the hose that is connected to the weep hole) and the other one connects to a filtered air source - like in your intake ducting after the air filter
Btw, there was no saving my oem gen 1 optispark. At 26000 miles it was all rusty and corroded inside because the seals cracked and let moisture intrude in.
If you dont see that mitsubishi symbol on your optical sensor then its not an OEM part.
Good luck!
Amen.
