Shocks
Old Sep 18, 2015 | 05:26 PM
TnEBill's Avatar
TnEBill
Default Shocks
My 1989 has Bilstein shocks on it. I have no idea what shocks came on the car, if these were what the factory chose, or if they were changed out by a previous owner. I know the car should have a pretty stiff ride to it, but if I hit a bump in a corner, the car jumps sideways. I'm sure shocks have come a long way from when these were put on the car. What is the current state of the art for a car of my vintage?
Bill
Old Sep 18, 2015 | 06:30 PM
WVZR-1's Avatar
WVZR-1
Bill
If you would like to ID what you have presently there should be information on the shock-tube body that ID's the build. From that information it could be determined as to whether they're OE or perhaps a Bilstein (other than OE) added to the car.
3 digit RPO's from the console label could ID the original build. The codes with FXX & ZXX would be the more interesting to check. XX being potentially a letter & number or numbers only.
Old Sep 18, 2015 | 06:34 PM
1994DelawareCoup's Avatar
1994DelawareCoup
Bill
Bilstein is the original shock from the factory. Purists will only use the original part on their cars but you don't have to. There are other options but a lot depends on how you drive the car and what type of ride you want. They are easy to replace and you can do it yourself but may not fix your problem. If the front end is original you could need bearings, tie rod ends or bushings. Jack her up , grab the tire and try to shake it from 3 o'clock to 9 o'clock then 12 o clock to 6 oclock. Look for play I'n the suspension. Anything that moves is suspect and may need replace or rebuild. If the suspension does not move but you still have play then it's probably the bearings.
Old Sep 18, 2015 | 10:08 PM
HAD2HAV2's Avatar
HAD2HAV2
Correct me if I am wrong but aren't Bilstein's warrantied for life and rebuildable? I replaced my Bilsteins after I read this. I still my original 88 Bilsteins though.
Old Sep 18, 2015 | 11:11 PM
Dakotaz's Avatar
Dakotaz
I think you are correct but you need to be original owner with proof of purchase. Please correct me if I'm wrong because I just replaced the four on my 90 vert and still have them. Might have just blown $380.
Old Sep 18, 2015 | 11:51 PM
HAD2HAV2's Avatar
HAD2HAV2
I think you're right, me too. I replaced with Eldebrock shocks.
Old Sep 19, 2015 | 12:56 PM
whalepirot's Avatar
whalepirot
As second owner, I paid for the rebuild to Challenge Spec and could not be happier with the ride/handling in my Z51 car.
Jumping sideways? Is that in a corner while hitting a bump?
Old Sep 19, 2015 | 01:49 PM
eldertek's Avatar
eldertek
Default Shocks
Changed my old bilsteins for new ones.
I couldn't believe how Easy it was!!!
Old Sep 22, 2015 | 06:59 AM
TnEBill's Avatar
TnEBill
Do you have the part #'s for those Edelbrock shocks?
Old Sep 22, 2015 | 07:05 AM
WVZR-1's Avatar
WVZR-1
Buy parts that have recommended applications from vendors/manufacturer for your MODEL YEAR car. Don't rely upon what others have used for accuracy regarding applications.
Old Sep 22, 2015 | 07:19 AM
TnEBill's Avatar
TnEBill
That's the problem, I can't find anywhere on the Edelbrock site where they even make shocks, let alone for a Corvette... Eckler's has Edelbrock shocks, but only a short blurb about them. I'd like more detailed info on ride, valving, etc. And now I just noticed that they are "discontinued"... So who makes a similar shock? Did someone take over their "patented Inertia Active System"?
Old Sep 22, 2015 | 07:26 AM
WVZR-1's Avatar
WVZR-1
Edelbrock I don't believe has sold shocks for quite some time. Why would you be interested in purchasing a product that regardless of the vendor purchased from they can't offer support?
Old Sep 22, 2015 | 07:41 AM
TnEBill's Avatar
TnEBill
So sorry for the confusion. I thought I asked, "who makes a similar shock?"
Old Sep 22, 2015 | 08:09 AM
WVZR-1's Avatar
WVZR-1
No confusion. I was looking at your post #11 before you "added" this comment and when I clicked on the reply it picked up of course the NEW entry with the edit.
Old Sep 23, 2015 | 01:28 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Bilstein makes shocks.
Koni makes shocks
QA1 makes shocks
To Shocks
