Keyless Entry Problems
Old Aug 23, 2002 | 02:16 PM
Atchisbr's Avatar
Atchisbr
Default Keyless Entry Problems
I own a 96 Coupe that has recently developed a problem with its keyless entry/security system. For some reason it will no longer lock the doors when I exit the car, or unlock the doors when I approach the car. I thought it might be a bad battery in the key fob, but I changed it to no avail. Also, when I get into the car the door locks begin to cycle between lock/unlock by themselves and the hatch begins to pop open repeatedly....it even popped open while I was driving.
Anyone heard of this problem? Anyone know how to go about fixing it?
Any info would be great!
Bryan
atchisbr@go.com
Old Aug 23, 2002 | 05:00 PM
all4c4lt4's Avatar
all4c4lt4
Default Re: Keyless Entry Problems (Atchisbr)
I thought (and could be wrong) that you could disable the automatic lock/unlock feature on the 96 with the keyless remote. This doesn't solve your problem, but it will prevent weird things from happening until you can fix it (hatch opening while your driving? :eek:)
Check your manual, thats where I remember seeing it.
Old Aug 23, 2002 | 06:04 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Keyless Entry Problems (all4c4lt4)
If you want to deactivate the PKE system, hold down the door button on the FOB
for about 5 secs. you shud hear/see the door locks cycle. Reactivating is the same procedure. It sounds like you may have a problem with the door/ajar switches?
Old Aug 23, 2002 | 06:16 PM
Atchisbr's Avatar
Atchisbr
Actually, I have tried turning the system off with the remote...but it doesn't seem to work.
Thanks for the info!
Bryan
Old Aug 26, 2002 | 11:33 AM
KDSharpe's Avatar
KDSharpe
Bryan,
Mine started doing the exact same thing on Friday! We tried replacing the battery also, but of course that wasn't it. Right now I have to mannualy lock/unlock my car until we figure out what this problem is. Have you been able to fix yours yet? If so, how? Unfortunately, I don't have my owner's manual.
Please let me know if you find out anything and I'll do likewise.
kimberlysharpe@hotmail.com
Thanks!
Old Aug 29, 2002 | 11:07 AM
Atchisbr's Avatar
Atchisbr
Default Re: Keyless Entry Problems (KDSharpe)
I think I replied to an email you sent earlier in the week, but for some reason my email server just delivered it to me again...so I figured I would cover my bases.
When my was messing up it wouldn't lock/unlock when it should have but would do it at the strangest times...including 'popping' the hatch while I was doing 35 mph down the road...that isn't good.
All of a sudden the other day it starts to work. The only problem I have now is that it takes a lot longer for the car to lock upon exiting, the interior lights do not stay on now before locking, and I cannot turn the PKE system on or off with the remote.
If you find anything else out please let me know also.
Bryan
Old Aug 29, 2002 | 12:24 PM
RadPolo96's Avatar
RadPolo96
Have you thought about hireing an exorsist? :lol: I have never heard of that happening. If it started working again thats great, but if it doesnt you probably wanna have someone look at it. The unit maybe going bad.
Old Aug 29, 2002 | 12:48 PM
95Purple's Avatar
95Purple
Default Re: Keyless Entry Problems (RadPolo96)
My 95 does the same thing :mad So to fix it I took my keys off the remote and hid it in the house :smash: as far away from where I park my car as I can :rolleyes: I use the key to unlock the doors, it not that hard. But if someone comes up with the cure it would be nice. :yesnod:
[Modified by 95Purple, 11:49 AM 8/29/2002]
Old Aug 30, 2002 | 11:16 AM
KDSharpe's Avatar
KDSharpe
Bryan,
Yes, I did get your e-mail, thanks! Mine is now de-activated until we can get it looked at. My husband thinks it may be a fuse, but he would rather have someone look at it that knows what they're doing. It's a pain in the butt having to use the key to unlock...I'm spoiled on the PKE!
Bryan
Old Aug 30, 2002 | 12:58 PM
Lone Ranger's Avatar
Lone Ranger
Check owner's manual for procedure for programming each keychain transmitter to work with the car's reciever/xmitter. I had same problem and that fixed it on my '95. Might have been the batteries ran low enough in the keychain xmitters to cause loss of recognition by the car and now even with new battery it won't work because the car no longer recognizes the keychain's code because the keychain's code needs to be programmed back into the car's memory.
If that doesn't work, try pulling the battery juice on the car and let it sit awhile, then reconnect car battery and go through keychain programming procedure per the owner manual again.
Old Aug 30, 2002 | 07:05 PM
Atchisbr's Avatar
Atchisbr
Default Re: Keyless Entry Problems (Lone Ranger)
Lone Ranger,
This problem actually started a few days after my car's battery went totally dead. Possibly that messed up something in the computer. I will have to check and see if disconnecting that battery will fix my problem.
Thanks!
Bryan
Old Aug 30, 2002 | 07:06 PM
Atchisbr's Avatar
Atchisbr
Yes...I too am spoiled on the PKE...that was one of best parts when I first got my Vette! hahaha
To Keyless Entry Problems
