Code 36, Help!!
Old Aug 23, 2002 | 03:21 PM
dmac's Avatar
dmac
Default Code 36, Help!!
Replaced o2 senser, intake manifold gaskets, fuel filter, maf and both relays, which eliminated a code 34 and engine runs much better, but am now getting a code 36. Mechanic is having trouble correcting this code 36. Any advice or suggestions will be appreciated. Thanks dmac
[Modified by dmac, 7:38 PM 8/23/2002]
Old Aug 23, 2002 | 03:54 PM
dmac's Avatar
dmac
Default Re: Code 36, on 1986 Help!! (dmac)
Anyone have any idea what to check with a code 36?
[Modified by dmac, 8:00 PM 8/23/2002]
Old Aug 23, 2002 | 04:01 PM
dmac's Avatar
dmac
Forgot to mention that this a 1986, with 31,000 miles.
Old Aug 23, 2002 | 04:32 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
CODE 36 IS BURN OFF RELAY FOR MAF OR MAF ITSELF.MINE GAVE CODE 36 AND REPLACED RELAY.CODE GONE BUT CAME BACK IN A COUPLE WEEKS.I PULLED ECM FUSE AND ERASED CODE.SINCE THEN CODE 36 HAS NOT COME BACK.I THINK IT HAS TO DO WITH A PLUG OR CONNECTOR OCCASSIONALY LOSING CONTACT.ALSO WHAT I DO IS WHEN I GO TO START CAR THEN I TURN IGN TO ON AND LET ALL GAUGES RETURN TO ZERO BEFORE I START ENGINE.
Old Aug 23, 2002 | 05:52 PM
dmac's Avatar
dmac
Default Re: Code 36, on 1986 Help!! (vert2go89)
Thanks for the tip. The mechanic got it cleared, he said the 2 relays for the MAF sensor were reversed???? Not sure on that one, but I runs a heck of lot better.
To Code 36, Help!!
