Ignition Wire Decision .
When i got my 84 the previous owner gave me some new MSD wires,
I installed them along with #2 platinum plugs.
Not too long after i got bad misfires, and rough running, rough idle, electrical current was shorting to the block on the outside of the wires.
Turns out the MSD wires i had were smooth inside the boot, and the #2 plugs were also smooth on the porcelin. So the wires back off the plug. Don't know if those wires were the correct part number though.
Ok, so i order ac delco wires and the copper stock plugs, which have ridges on the inside of the boots and on the procelin of the plugs. This helped hold the wires to the plugs. None came loose.
Car runs great for almost a year.
Then same issues.
The ac delco cap and rotor i bought at the time are GARBAGE, the rotor plate had a hole in it after about 7 months.
So replaced the cap and rotor with napa brand, problems went away though at that time the wires were toast because when i repainted the valve covers i never installed the original wire loom separators and they were touching the headers and shorting out and became brittle.
So once again 7 months later, same problems, i replaced the cap and rotor with bwd brand from oreilly's.
Changed the wires to the autozone brand stock size 25 bucks as compared to the ac delco at 55 bucks, routed them per the FSM, and installed the stock wire loom separators.
Have not had issues since.
Though i can see changing the cap and rotor every year for safe measure.
In essence just make sure you have the correct type/length wires, plugs for the 84.
Use the stock wire looms.
Route the wires correctly per the fsm.
Gap your plugs correctly !! ( 5 of the 8 i bought were all the wrong gap)
DO NOT use anti seize compound on the plug threads, this will just give you more misfires.
Change your cap and rotor annually ( cheap insurance against failure ).
If you have not done so it does not hurt to get a new ignition pick up coil ( or rebuilt distributor ) mine had hair line cracks in the wheel that could not be noticed until you took it out, and ignition module as well as new ignition coil and correctly time your engine, mine is at 6 degrees BTD. It was a PITA, but i'm glad i did it when i first got my 84 thanks to all the members here who always have great advice for their help!
routing & length can be to the user's discretion. Providing they are safe. I have tried MANY MANY wires. Traditional carbon cores SUCK.
The super conductors have been. By-far the BEST. Until my current $Magnecore$ expensive. But extremely good wires. You have it Easy with a Large base Dist.. You must, not have experienced the Opti system. I guarantee. You will not change that cap/rotor & wires. Every year..
When i bought this car everyone asked why i wanted such an older model, and the opti is just one of many reasons i wanted something simpler and easier less expensive to work on since i turn my own wrenches.
Great info on the wires thank you!
There's a you tube video on the subject and as Joe C pointed out some plug makers say not to use anti seize.
A mechanic i know told me to use the least amount of anti seize possible.
I agree that plugs left in too long or over torqued can get frozen into the head which is why i used it. But learned quickly that perhaps too much can lead to misfires on iron heads.
On aluminum heads I'd still use it though, no sense galling threads on a head.
I'm also always up for installing better quality or better performing parts, my experience naturally led me down the road to just keeping things stock and installing them per the fsm to get the best performance for my stock application.
I have owned 3 set's superconductor universal. Crimp your own. On my 383 build. I took my previous low mileage MSD's from my TA Cut the ends off and installed the Opti fittings. Never witnessed a TESLA light show. Only improvement over Stock Carbon core wires.
