HELP Tail Light Problem
Old Sep 25, 2015 | 10:55 PM
NYMets618's Avatar
NYMets618
8th Gear
Default HELP Tail Light Problem
Hello all, I just bought my first Corvette a 1988 convertible in need of some tlc.
So my problem is, my brake lights all work, directionals all work but when I turn on the headlights, nothing in the back lights up. The tail lights do not light at all.
Any help with this is greatly appreciated.
Thank you,
John
Old Sep 25, 2015 | 10:58 PM
NYMets618's Avatar
NYMets618
8th Gear
By the way, just to add, the brake lights also work when the headlights are on, but when you take your foot off the brake pedal all the lights in the rear go dark, no tail light.
Old Sep 26, 2015 | 12:06 AM
Cliff Harris's Avatar
Cliff Harris
Check the TAIL fuse (seems obvious, but who knows?). Do your fog lights work? (They also use the TAIL fuse -- parking or headlights must be on).
The tail light circuits and brake circuits are completely separate.
The power for the tail lights comes from the headlight switch. Does your license plate light work?
Old Sep 26, 2015 | 12:20 AM
NYMets618's Avatar
NYMets618
8th Gear
Thanks, I will check all that tomorrow morning and post back.
Old Sep 29, 2015 | 10:47 PM
NYMets618's Avatar
NYMets618
8th Gear
Thanks ! It was the fuse all is good now.
To HELP Tail Light Problem
