Reverse lock out
Old Sep 28, 2015 | 02:08 PM
DAVECAD2.0's Avatar
DAVECAD2.0
Default Reverse lock out
1992 LT1 ZF 6 SPEED.
Trying to locate the reverse lock-out **** on the shifter.
The "plastic" **** cracked at the set screw leaving no reverse.
Searched the interweb and all the usual parts house's, nutten!
Greatful for any help.
TIA, Dave
Old Sep 28, 2015 | 02:26 PM
RWDsmoke's Avatar
RWDsmoke
TIA, Dave
You might try zfdoc.com. It is a real pain to have to push your corvette out of a parking space. Or use needle nose pliers on the rod to get it in reverse. After replacing mine twice I made one with steel inside where the set screw goes. It took a lot of time grinding and filing but it works.
Old Sep 28, 2015 | 04:08 PM
WVZR-1's Avatar
WVZR-1
10079757 at the dealer and some other vendors also I'm sure.
Old Sep 29, 2015 | 08:14 PM
DAVECAD2.0's Avatar
DAVECAD2.0
Thanks "R" for the part no.
Old Sep 29, 2015 | 08:19 PM
DAVECAD2.0's Avatar
DAVECAD2.0
Thanks dubya for the part no. Ordered one from GM Parts East.
To Reverse lock out
