1985 Intermittent Starting Problem
Old Sep 30, 2015 | 10:48 PM
DarkObsession's Avatar
DarkObsession
Default 1985 Intermittent Starting Problem
I've got what I think is an odd electrical problem. Sometimes my car won't start, it won't even crank. The problem generally happens after I've driven the car for a while, let it sit for an hour or two, and then try to go start it up again. Here's how it goes:
  • Get in the car
  • Turn the key to the point where everything electronic starts firing up
  • Turn the key to start and nothing, all the electronic stuff turns off
  • The car won't turn over
  • I can hear something that makes a click sound in the inside rear of the car every time I turn the key to the start position
The battery always has a charge when the car does this. The first time I thought the battery was dead and had someone give me a jump. I think the jump moved the battery cable enough to get it to start. Here are some of the things I think it might be:
  • Corroded positive terminal
    • The second time the car died I tried jumping it again and it wouldn't do anything
    • Took the battery cables off to inspect them and found a lot of corrosion on the positive contacts that touch the battery
    • Put the cables back on and it fired right up
    • I've since cleaned the cable contacts and battery thoroughly with cleaners and with a Dremel
    • No corrosion anymore but the problem still happens
  • Another idea is that it's something in the wires that come out of the positive connection (but not the biggest cable running to the starter)
    • Tonight I got to thinking the problem might be in the little wires and connectors that are in the positive cable
    • Maybe moving just them around when undoing and inspecting the cable move them enough to get them in the right place
    • I don't have any idea what these cables do though so I'm just not sure
For right now moving the cables is working but it's a really annoying problem. Also, I hate having to pop the hood and mess around with the battery when other people are around. Always seems to get people that want to help, even though the last time they knew anything about a car was when their oil change guy asked them if they wanted to do service upgrades. Anyone have any thoughts? I'd really appreciate them!
Old Sep 30, 2015 | 11:06 PM
antfarmer2's Avatar
antfarmer2
pull the battery out and clean up the connection to the block where the pos wire goes
Old Oct 1, 2015 | 09:16 AM
DarkObsession
I've cleaned the wires and the battery a couple of times with wire brush, Dremel, and electric contact cleaner so I don't think the problem is there. Last night when the car wouldn't start I took everything apart again and there wasn't any corrosion that I could see. I'm waiting for it to act up again so I can see if jiggling the other wires on the positive cable makes a difference. Was just hoping someone else might know what's going on.
Old Oct 1, 2015 | 09:25 AM
antfarmer2's Avatar
antfarmer2
then try what I said pull the battery out there is a block that the small wires go to clean there!!!!!
Old Oct 1, 2015 | 10:46 AM
WVZR-1's Avatar
WVZR-1
You're chasing the OP on an adventure that he doesn't need to be concerned with. The "jump block" wasn't added to the C4 until '86 I'm quite sure. The OP's related connections that he needs to be concerned with are the battery, the starter motor and forward through the cranking/start circuitry.
The OP needs to likely just concentrate on maybe a clutch switch, neutral safety, starter interrupt or potential ignition switch situation that could be electrical or possibly mechanical in failure to the rod/pawl from the key cylinder IF/ONCE he confirms the condition of cable connections to the battery and the starter motor.
Old Oct 1, 2015 | 11:19 AM
antfarmer2's Avatar
antfarmer2
thank you I stand corrected thought they all had them
Old Oct 1, 2015 | 11:38 AM
HlhnEast's Avatar
HlhnEast
I would also check that your starter connections are clean and tight, both the big and small wires. Check your ignition switch near the bottom of your steering column. It would be really good to have a DVM handy when this problem occurs to check the switch for voltage and other places in the power circuit. You can get a cheap DVM at Harbor Freight for about $10. Intermittent issues are kinda tough to diagnose so having the right tools handy will help tremendously.
Battery cables will also corrode internally where it wont necessarily be obvious there is an issue. They arent that expensive so replacement may cure your issues. When you moved the cables around cleaning them you may have helped it make a better connection. With you losing all power I would suspect them being the culprit.
Try all the free stuff first. Sounds like your working in the right direction and keep checking all connectors. Dont forget the grounds, they are just as important especially with our plastic cars.
Old Oct 2, 2015 | 12:34 AM
Cliff Harris's Avatar
Cliff Harris
  • Get in the car
I had the exact same symptoms. It turned out to be a leaking battery terminal that ate up the wire inside the positive battery cable.
Old Oct 2, 2015 | 08:06 AM
DarkObsession
Thanks everyone. I was hoping this would be one of those "oh yeah, that happens a lot on 85s and it's easy to fix" problems. Looks like I've got some investigating to do. I'll post back if I can figure it out. Thanks again.
Old Oct 2, 2015 | 08:21 AM
WVZR-1's Avatar
WVZR-1
Relatively simple diagnostics and checks I'd think. Check the integrity of the battery terminal connections (which it seems that you have), do the same at the starter motor and the appropriate ground points for the negative cable.
It is kind of an "oh yeah" for any 30 year old car. Do you know that either of the battery cables have been changed?
If checking, confirming repairing/replacing battery terminations doesn't provide long term fix then it's on to the other potential culprits.
Old Oct 2, 2015 | 08:29 AM
DarkObsession
As far as I can tell the cables are original but I'm not sure. I only got the car about 6 weeks ago and before that it had been in storage for a long time. It's probably something simple but I've just got to work through it.
Old Oct 2, 2015 | 08:32 AM
DarkObsession
Also, just wondering if anyone knows what the other little wires coming off the positive post go to?
Old Oct 2, 2015 | 08:58 AM
WVZR-1's Avatar
WVZR-1
For an '85 I'd think one to the ECM and another to the cooling fans, if there's a multiple fusible link in one then it's likely that it's the HL lift circuits maybe. If you've got an AUX fan then there would likely be multiple FL for that also.
Old Oct 2, 2015 | 10:50 AM
confab's Avatar
confab
If you can jump/use a remote starter switch and get it to turn over? It's possibly an ignition switch issue, as someone suggested above.
Old Oct 2, 2015 | 05:23 PM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
I had the same problem with my 91. Did you pull the battery bolt out of the rubber housing on the end of the cables? That's where I found my problem. The cable was actually rusted under the head of the bolt.
Old Oct 3, 2015 | 10:07 PM
DarkObsession
No, but that's a good suggestion. There was surface rust on the exposed parts of those bolts so rust inside wouldn't surprise me.
To 1985 Intermittent Starting Problem
