1986 convt. L98
Old Oct 5, 2015 | 06:42 PM
ragstoy's Avatar
ragstoy
Default 1986 convt. L98
I am trying to locate the oil temp sensor in the fsm. Mine is reading 320 degrees. I think mine is bad.
Rich
Old Oct 5, 2015 | 07:39 PM
confab's Avatar
confab
On my 85, I believe it's down on the side of the black. Driver's side, by the oil filter.
Old Oct 5, 2015 | 11:56 PM
Cliff Harris's Avatar
Cliff Harris
It's on the side of the block above the oil filter. The green wire and connector surrounded by all the ground wires on G104:
For reference, the part looks like this:
Old Oct 7, 2015 | 02:51 PM
ragstoy's Avatar
ragstoy
I have the oil temp sensor out. Is there any way to test it. I am assuming that is bad because of the reading I get (320f).
Also can I get the part. I am told that it was discontinued by G M .
Rich
Old Oct 7, 2015 | 08:03 PM
c4cruiser's Avatar
c4cruiser
Rich
Try these part numbers:
Airtex # 1T1076
Standard Motor Products TS159
About $60 at Rockauto
Old Oct 7, 2015 | 08:56 PM
crowz's Avatar
crowz
Rich
If its reading 320 when cold then yep its toast. If its reading that anytime its probably toast. Simple test is to just unplug it and see what it reads.
Old Oct 8, 2015 | 01:35 AM
Cliff Harris
You can measure the resistance and it should correspond to a temperature per the following chart (yes, I know it says coolant sensor, but the temperature sensing element is the same):
Old Oct 10, 2015 | 01:30 PM
ragstoy's Avatar
ragstoy
I disconnected the sender and the gage reads low, so I guess the sender is bad. Ordered one from rockauto thanks to cliff.
Rich
Old Oct 10, 2015 | 01:32 PM
ragstoy's Avatar
ragstoy
Thanks to c4cruiser
Rich
To 1986 convt. L98
