Test N Tune
Old Oct 7, 2015 | 11:31 PM
rssshen vette's Avatar
rssshen vette
Default Test N Tune
I went to the track today for test in tune to see how well or poor my car would do with the current tune. The local track is an 1/8 mile and the track prep wasn't all the great. I was using Nitto drag radials for the first time. I usually use BFG Gforce Drag radials and as soon as I burn off the nittos I'm going back to BFG's. I made 4 passes and the best pass of the evening was
60ft.....1.7686
330ft....5.1239
594ft....7.4206
1/8 mi...7.9377
1/8 MPH... 87.01
On this pass I lowered my tire pressure down to 16psi and my launched off the line spinng through 1st gear. My car was running very rich( lot of black smoke from the exhaust). So I hope to get a updated tune after I get a few dyno runs to get an accurate air fuel ratio to work from.
Old Oct 8, 2015 | 03:25 AM
blackozvet's Avatar
blackozvet
which Nitto's were you using ?
what sort of mods and rear end ratio are you running ?
Old Oct 8, 2015 | 07:02 AM
856SPEED's Avatar
856SPEED
Look at his signature below his comments........
Old Oct 8, 2015 | 07:15 AM
blackozvet's Avatar
blackozvet
I might be missing something, but cant see it ?
Old Oct 8, 2015 | 11:43 AM
rssshen vette
Nitto NT05R
Old Oct 8, 2015 | 11:51 AM
rssshen vette
1985 L98 383, Scat forged crank and pistons, 10:5 CR, 6" H beam rods, Dart 180cc Pro 1 Alum. Heads, Comp Cam XR 288HR (12-433-8), roller valve train, 1.6 int/ 1.5 exh, Mini Ram, 58mm TB, 30lb injectors, adj fuel reg, MSD6AL, LT headers, 3” front Y pipe, Hi Flo Cat, TCI kit, 3000 stall, and 373 gears.
Old Oct 8, 2015 | 12:34 PM
DanielRicany's Avatar
DanielRicany
I think that tune is definitely holding you back by a lot. But for how it is, it's still pretty fast.
Old Oct 8, 2015 | 01:32 PM
THE 383 admiral's Avatar
THE 383 admiral
a 383 build Miniram 3:73 With radial drags. Ouch. Get them to re-tune. send a data log. Your way to rich.
your hooking up great 1.7 60ft
My stock 94 LT1 street tires. LS coil conversion, CAI, & my tune. That's it. I also just found out my CATS were clogged from ceramic breakage. After installing my headers & Hpipe 4 days ago.
with a poor 2.1- 60ft
5.8- 330ft
8.8- 660ft
83.44 - 1/8
105.81 1/4 @ 13.477
Old Oct 8, 2015 | 02:44 PM
856SPEED's Avatar
856SPEED
I'll be honest with you...:1/8 mile runs are not enough to dial in a tune....I don't think I am getting out of third gear in the 1/8 mile. Data logging is fine though I agree with that....you want to see a trap speed in the quarter. With that miniram, you are making power in the big end of that track I am sure. Even if it's a little rich you can make a little more by leaning it out but even then you want to know how rich it is....dyno tune can help with that although no one touches these dinosaur ECM's anymore. But again these 1/8 mile runs are not enough to test a miniram car...little more than stop light to stop light.
I would bet with those 60 foots.....pretty damn good BTW, your car is well within 12's with the existing tune.
Old Oct 8, 2015 | 02:47 PM
856SPEED's Avatar
856SPEED
I see what you mean....it's not on my cell phone application but I can see it on my home computer
Old Oct 8, 2015 | 03:50 PM
rssshen vette
My 60ft looks good on paper. I actually had poor traction off the line and had to quickly shift to second gear.
Old Oct 8, 2015 | 05:58 PM
856SPEED's Avatar
856SPEED
I never have gotten a 1.7 60 foot...seems difficult with street tires and manual that I run....that is moving out by my standards!
Old Oct 8, 2015 | 07:51 PM
rssshen vette
You're 100% right 1/8 mile isn't enough to dial in a tune. My last tune was done by Ed Wright. Hopefully I can get my tune closer to dialed in within 2 to 3 adjustments.
Old Oct 9, 2015 | 05:42 AM
blackozvet's Avatar
blackozvet
you've got a very similiar setup to mine, except for my 3.07 rear and single plane intake.
are you running the '870 computer with a Fastchip ?
Old Oct 9, 2015 | 11:14 AM
rssshen vette
Yeah I'm running a 870 with a Fastchip. He's the only person I know of that still tunes chip for the 870
Old Oct 9, 2015 | 01:39 PM
856SPEED's Avatar
856SPEED
TPIS in Chaska Minnesota will do it on a wheel hub dyno...but you have to get the car to them. Having said that they will also do chips for the 870...not cheap but they are good!
Old Oct 9, 2015 | 03:28 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Sorry i dont understand 1/8 mile times as i only race 1/4 mile (and in my camaro). But i have a traction problem even running MT DR @ 18psi and cant get my 60' times under 2.1sec. So i need to get it to hook and that means a better torque arm and change my weight balance if possible. I dont run drag shocks and my camaro sits pointing down in the front - making it light in the rear on launch. Plan to fix those items to stop some wheel spin. Dang tires spin even if i baby the throttle on launch. I dont kow what the corvette guys use for a torque arm but u need something to keep the axle(s) from wrapping upward on a launch. I think when u get to a high pwr level the corvette axles tend to move the tires outward at the top (pos camber) and lose some traction as the rear end tries to "stand up". So the cure sometimes is a straight axle.
IMHO u may have something to gain in a tune but u need to hook to use it. Still will be a fast car, just will spin like on ice from a stop.
To Test N Tune
Old Oct 9, 2015 | 08:04 PM
96 lt-4's Avatar
96 lt-4
Play around with the air pressure and do a good (but not excessive) burnout.I used to run my DR around 20psi.
When you have a high torque car the stiff sidewall DR can be harder to handle the shock load to the tires.Add some low gears and a high stall and you hit the tires hard.A stock suspension won't handle well either.
A bias slick can absorb the shock load better and bite more.There is a limit for drag radials and stock suspensions for hooking.
Old Oct 9, 2015 | 08:22 PM
TA's Avatar
TA
A others have suggested I would get the tune dialed in and also I would forget the BFG or Nitto DRs and get a set of MT ET Street DRs.
Old Oct 9, 2015 | 08:50 PM
rssshen vette
On the street with street tires mounted my car will break traction that's to be expected given the mods I have. But on the track I know my car will hook it's just a matter of finding the right tire pressure that hooks. I've never used Nitto DR before so I was figuring out what psi will hook. My last set of drag radials were BFG's and at 26psi with a short burn out in the box my car would hook every time. during that time I ran a slightly small cam and a different tune and my best 60ft was 1.686 7.836 1/8 mile..
