Help with brakes
Old Oct 13, 2015 | 07:27 AM
mixalive's Avatar
mixalive
Default Help with brakes
I have a 92 base model with J55 brakes. It appears the brake pads in my left front are wearing more on one end of the pads. Could I have a bleeding issue on one of the brake pistons within the caliper? Maybe one of the pistons are hanging up?
Old Oct 13, 2015 | 04:36 PM
93Rubie's Avatar
93Rubie
Could be. Remove and inspect the pads for not being bound up in the caliper bracket. Push each piston in a bit to see if they move freely or if one has higher resistance to this or not. See if they drag a bit with the wheels off the ground as well on that side.
Not going to be a bleeding issue, if there was air in the system it would effect that side but the entire side not just one piston or the other.
Old Oct 13, 2015 | 05:47 PM
mixalive's Avatar
mixalive
Thanks for the info
Old Oct 13, 2015 | 07:54 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Like rubie said, make sure the pads are in correctly.
Old Oct 14, 2015 | 06:26 AM
HlhnEast's Avatar
HlhnEast
Sounds like its time to replace the calipers if the pad is positioned correctly.
Good luck!
To Help with brakes
