Engine Rebuild or Replacement
Old Oct 13, 2015 | 09:32 AM
GRNNREG's Avatar
GRNNREG
Default Engine Rebuild or Replacement
I would like a recommendation for a shop in Northern California to do an engine rebuild or replacement for a 1992 LT-1.
Thanks for your input.
Old Oct 13, 2015 | 09:38 AM
Vic'89's Avatar
Vic'89
An engine swap will save you time if that is a concern.
With rebuilding your engine, I am sure you will be without your car for several months.
Vic
Old Oct 13, 2015 | 12:25 PM
c4cruiser's Avatar
c4cruiser
You might want to start a thread in the Northern California section. Looks like you live in the Bay Area so there should be a number of good shops that can do the work. Might even help to state where you live and how far you would be willing to travel to get the car to a shop. Showing your location is always a good idea too
Old Oct 13, 2015 | 02:07 PM
mtwoolford's Avatar
mtwoolford
well , just my opinion, but good LT blocks are becoming fewer and fewer, and good lt blocks with four bolt mains are far fewer still....so I'd suggest, time permitting that you investigate rebuilding your present block; heads? there are a number of good aftermarket heads available, so rebuilding or replacing your present heads would be a judgment call.
Old Oct 13, 2015 | 05:39 PM
GRNNREG's Avatar
GRNNREG
"You might want to start a thread in the Northern California section. Looks like you live in the Bay Area so there should be a number of good shops that can do the work. Might even help to state where you live and how far you would be willing to travel to get the car to a shop. Showing your location is always a good idea too"
I followed your suggestion. Thanks
To Engine Rebuild or Replacement
