front marker lights
Old Oct 15, 2015 | 08:05 AM
hdrider1957's Avatar
hdrider1957
Cruising
Default front marker lights
i have a 1988. The guy before me tried doing away with the flip up headlights and change every light to leds and he made a mess of it. I have taken out everything he has done and have replaced them with original. I have brake lights, parking lights, headlights, fog lights and turn signals. The problem is the front marker lights have no power to them i have checked the fuses. What else can i check or should i just trace the wiring all the way back thru the harness Any ideas would be appreciated.
Old Oct 15, 2015 | 08:54 AM
WVZR-1's Avatar
WVZR-1
Are you talking about the "amber" side marker OR perhaps the "clear" corners?
Old Oct 15, 2015 | 09:19 AM
hdrider1957
Cruising
Default side markers
the amber front side markers
Old Oct 15, 2015 | 10:30 AM
WVZR-1's Avatar
WVZR-1
Do the ambers light at all with any operation of the park, headlamp, turn or hazard operation? You mention "no power" but there's several sets of circumstances that would actually power the side markers.
How about the rear? What do you have there? That could aid the diagnostics I'd think for the front. Do you have the FSM or are you just trying to "wing it"?
For grins, with the head lamps on and the turn signal activated do the "clear" corners function as expected?
Old Oct 15, 2015 | 02:04 PM
hdrider1957
Cruising
Every light operates properly in the rear and the front even the clears on the side work properly with lights on and light off just not the amber front side amber markers and Im just trying to wire it
To front marker lights
