ZF6 Rattle
a single mass flywheel, keeping reading that it should go away when clutch pulled in? mine doesnt. no change at all in or out. works great, no problems, just real noisy. normal or not?
Sprung hub spec stage 3+ clutch
Properly shimmd blue tag 'remanufactured' transmission. (Ie. Zf doc thicker countershaft shim installed)z
Tiny bit of light rapping at idle if you let the clutch pedal up and its in neutral - but who drives like that anyways? Lol.
Totally silent under all other driving situations
Im not even sure it has a single mass in it but previous owner said it has a brand new clutch in it so since dual mass ain't available im assuming
Its a single mass.
Its a single mass.
Its might understanding it can be quite noisy if you dont put in a sprung hub clutch when replacing the dual mass with a lighter weight single mass flywheel
Probably some nasty driveability issues too.
I wouldn't assume that. Most clutch replacements w/a DM flywheel involve scotch brite'ing the FW and reusing it.
The back lash, or clearance between the gears in a ZF6 is rather large - more than in other transmissions. Also, the gears in a ZF6 are big and heavy...again, more so than in other transmissions.
SO, the "ZF6 Rattle" is the noise created WHEN, the car is idling in neutral, BY the input shaft gear teeth whacking back and forth against the countershaft gear teeh as the crank accelerates and decelerates, several times per revolution...and the countershaft does not "want to".
NOW...the OP says that his car does this in gear. If the car is stopped, trans in first gear, what are the gears doing? They are doing nothing. They are stationary, along w/everything else, from the clutch disk, the the axle nuts. No way they can be causing a rattle, whether the clutch is dragging or not.
His rattle is caused by something else.
You may well be on the right track with looking at the accessories.
Does it get quiet when the clutch pedal depressed and the trans in gear? If yes, clutch isn't releasing all the way. If no, then the rattle is being caused by something else.
