rough running eng
Old Oct 18, 2015 | 05:45 PM
rimrider99's Avatar
rimrider99
7th Gear
Default rough running eng
just bought a 94 coup, power washing eng and would not start. let it set a couple days and it started but still runs ROUGH. Now where do i start to fix it. 64,000 miles
Old Oct 18, 2015 | 06:25 PM
antfarmer2's Avatar
antfarmer2
well you just did the worst possible thing you could have done. sounds like your going to learn about the opti spark. do some reading in here. if you have a little heater with a fan put it on the opti on low heat and pray.
then look at it in the dark look for arching and sparking along the spark wires clean and a bit 0f dielectric grease and make sure all click twice.
Old Oct 18, 2015 | 06:39 PM
rimrider99's Avatar
rimrider99
7th Gear
well i run it up to temp, let it set for a hour now wont start. looks like i got a big lesson coming! thanks
Old Oct 18, 2015 | 09:15 PM
John A. Marker's Avatar
John A. Marker
The Optispark for the 94 is not vented, check out PETRIS OPTISPARKS.
you did the worst possible thing by power washing the engine. Not only did you clean the engine...but look like it cleaned out you wallet at the same time.
Old Oct 18, 2015 | 09:37 PM
antfarmer2's Avatar
antfarmer2
do not toss the old one and lock your hammers up for awhile
but first leave the low heat fan on for a few days
and clean the drain hole by the gas cap before you learn another trick
To rough running eng
